Greetings from Santa Cruz, California
redbat
Hello all,
I've been lurking here since 2015, but this is my first post.
I've been interested in watches for a few years now and am now considering taking some time off of work to take the BHI distance learning courses in the hopes of making a career of watch and clock repair as an independent.
I've been acquiring tools and information for a while, and recently learned how to disassemble and reassemble a 6497 movement in preparation for the SAWTA course at the Watch Technology Institution admission test at North Seattle College.  I have recently come to the conclusion that I cannot make the move to Seattle for 2 years to attend the program, which is why I am now considering the BHI courses.
My most recent repair has been to my Maktime (Poljot) 3133 chronograph; the glass had gotten cloudy on the inside, so I had removed the movement from the case to clean the glass, and made the rookie mistake of not inserting the stem correctly, which meant removing the calendar works to reset the keyless works.  In the process of doing this, I did not correctly replace the date indicator driving wheel, which uses a small hooked wire connected to a planetary gear inside the driving wheel to move the teeth of the date wheel.  Figuring out how to adjust this correctly and reassembling the watch with a working date wheel was a wonderful feeling.
Anyway, apologies for the novel, and I'm looking forward to participating in the forum!
Greetings, thanks for the introduction.
It's too bad that you can't attend the school in Seattle. I think that having access to modern (and expensive) tools and equipment, along with the instructors to demonstrate how to use them, is invaluable. Especially if you are planning on making a career of this.
But, I agree, pulling up stakes is hard. I can't do it either, at my age I'd never recoup the investment. But who knows? I may do it anyway :)
Edited by dadistic
Noticed your location
Hello and welcome to the forum.
Nice job sorting out the Poljot issue.  In this line of work there is much to be learned from mistakes provided you're disinclined to throw in the the towel.
What a great idea to take the BHI courses- that's something I should probably look into also.  I've heard about the courses offered up in Washington and I think also in Texas or Oklahoma but like you, packing up and moving isn't really an option right now.  Hopefully things will work out in your favor to keep you on your desired schedule.
Great profile image by the way.  I just love flying foxes.  :biggrin:
Hello Redbat,
had to smile when I read your lead in. In the past I have also made all those sort of mistakes, in fact I would hazard a guess that lots of us have but philosophy jumps in to say mistakes are just lessons learned. Expletives also help in the moments after such lessons are learned of course
Welcome from me
Cheers,
Vic
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
