orient cal.1946 help
Morning guys, I've been trying to source any info on the orient cal.1946 21 jewel auto movement. Ive been unsuccessful over on watchuseek forum where they have a dedicated ( but quite possibly a very cliquey ) orient forum.
They only seem interested in "what mako are you wearing today" threads etc and not actually helping out. That's my opinion formedover the last two weeks.
Anyway,  I will be in the process of stripping and cleaning said movement soon, now I notice the day date doesn't quick set, I have tried pushing the stem/crown in aka seiko, but it does nothing part from operate a lever that protrudes out of the movement around the 2 o'clock position.  The day/date will change when hands are rotated but that's it.
I've looked on the bay for a spare movement that I could look at but they all seem to have a pusher on the case for quick setting the day/date, my particular one has not got a pusher.
Is there any specific nuances this particular movement that I need to know before I start?
Any info greatly appreciated especially from anyone that's worked on one of these before.
Dammit I don't have one sitting around, ohwell not to worry.
I've worked out the quick set for the day, wind on till day changes then carry on till say around 2 o'clock then reverse the hands then go forward again till around 2 o'clock and the day changes, continue doing this till desired day is displayed.
But I can't find anyway of quick setting the date, any one got any ideas on this one
If that is the seahorse type movement you can wait till the date changes at 12 then move the hour hand back to 9 you may get a slight click then wind forward past 12 again and keep repeating. My Glycine works that way as well.
Cheers,
Vic
Sorry transporter,
I thought that my suggestion was different from what you had advised but if both methods produce the same result I guess its back to the drawing board
Cheers,
Vic
Cheers,
Vic
  • 2 years later...
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
