I have an old small Seiko quartz watch with a case number 200834 and stem number 2E20-6300.  Some time after a repair of the stem by a jewelry store, the stem began to malfunction again and the crown got loose and was lost.  After watching a few of the repair videos on your website, I thought Seiko design should be just as straight-forward, and I might be able to do the repairs myself.  So, I purchased a new stem and a new crown and tried to remove the stem after attaching the new crown by pushing on any of the holes or screw-looking spots or levers to unlock the catch.  Unfortunately none of them seemed to budge.  In the process of fiddling, the watch internal popped out of the casing with the seal now loose.  I would appreciate any help that anybody could offer.  I guess I may have to purchase some very small screw drivers if needed.  FYI: I am attaching two pictures of the watch, one for the back side of the internal and one for the watch back cover. In the first post-271-0-46905300-1405747121_thumb.jpgpost-271-0-64336000-1405747144_thumb.jpgpicture, the watch internal is just resting on the watch casing.  Thank you.
Thanks for your prompt reply.  Comparing the info and picture in the manual you provided and the back side of my watch as shown in my picture, I was still not sure which hole/spot you thought was the best bet.  However, I tried again in vain all the spots and holes I could see on the watch back.  The following is what I have found with those spots in the earlier picture (I could not attach a WORD file with added shapes for illustration):
First Group: Dark spots/holes in the dark area of watch internal clockwise beginning with the large golden circular hole
Spot 1: Thought to be your most likely candidate but shallow, having a shiny golden top, and not budging when pushed with a pin while pulling on the crown at the same time
Hole 2: 2nd best candidate but not budging when pushed
Hole 3: Having something under looking like shiny metal wires but not budging when pushed down or pushed sideways
Hole 4: Not budging when pushed
Second Group: Golden spots in the silvery plate area
Cutouts 5: Looking like circular cutouts in the silvery plate above a gold plate
Third Group: Shiny circular spots in the dark area,
Spots 6: Looking like silvery circular discs but not budging when pushed.
I remember that several of the videos and advices on your website cautioned against pressing too hard on the release button since it could completely disengage some parts.  Therefore, it would seem that the correct button should not really require a lot of force (than I had applied) to push down in order to release the stem catch.  So, I am just not sure that we have found the right catch-release.  By the way, my watch # is 2E20B and not 2E20A but I don’t believe it matters.
I also remember that some of the video instructions showed another type of watch stem release which is by means of pushing back a lever that moves and/or appears near the stem when the stem is pulled out for moving the hands to adjust the time.  I wonder whether that might be applicable to my watch.  For a better look, I am attaching another picture showing a slanted view of the stem side.  The picture is not perfectly focused apparently because of the rapid change in the field depth over the whole picture in this view.  Again, I tried to push in each of the parts visibly out but nothing budged.  Any suggestion?
Of course, if you, or someone else, are pretty sure of the hole/spot to push in, I would be willing to try again by making sure that I properly pushed it in while pulling on the crown.
I would try pushing what appears to be a button between the N in Japan and S in Seiko. Try withe the stem pulled out to the setting position.
its going to be somewhere around here, a little lever with a small indent on it, a pin is ideal to apply a light pressure on it. with a magnifier push the stem in & out a few times & you will see it moving in & out.
Geo, r063rto, and Lee: Thanks for your replies.  I will try them and report back the results.  In the meantime, I thought I still should attach the picture of the side view of the stem hole area that I meant to attach but forgot during the last round, although the picture is not very clear in that dark area.  This picture is more relevent to the suggestion by Lee.
