This is my first wrist watch tear down and rebuild.
My usual course of action is to take a movement apart in stages and rebuilding, going deeper each time I tear it down. I have taken down the watch to the point of removing train and the complete mainspring barrel. When powering down the mainspring the screwdriver slipped and the spring unwound a little to fast.,I  checked it and it seems fine. When rebuilding the watch I wound it using the screw driver to test the train and pallet. all functioned well. Problem is when I release the click The mainspring does not unwind anymore. I am confused because the hairspring is moving and getting power.  Where may I have gone wrong?
Anthony
Edited by adiorio110
When the pallet is moved & the escape wheel turns then there is some power in the train of wheels. Strange that the barrel is not unwinding when the click is released. Perhaps the spring is not fully winding in the barrel and slipping before fully wound.
Hi Adiorio,
On most automatic watches, the AutoZone will prevent the barrel from unwinding. On these Seikos, you would need to remove the intermediate winding wheel .. the wheel which is secured by a screw with 3 lines. This is a left-handed screw so you have to turn clockwise to remove.
Anil
That was my thought at first but when I remove the second reduction wheel while holding back the mainspring barrel it would then unwind.
32 minutes ago, anilv said:
Hi Adiorio,
Anil
I guess we are talking about same wheel I know it as the  "second reduction wheel" . Thing that confuses me is the first time I thought the reduction wheel was in place. I probably had it removed and forgot. After reviewing Marc's video I see you are absolutely correct.
Well I guess all is good then. On to the next stage.
Thanks Guys
Regards
Anthony
I have now taken apart and rebuilt the 7s26c 3 times, dry runs no oiling, I like to get the mechanics down first  The first time out I broke the plastic day date collector wheel. Dman2112 was so kind as to donate the part as soon as it gets here I will tear it down again and oil it.
Hi , are you working on a 7S25C and a 7S26C both . I saw you have 2 posts and you use both calibers . The date part # you show is similar but different for both calibers .
In any case as I read this post it sounds as if you have proceeded correctly so far .  In checking the train wheels for free movement , remove the autowind bridge and parts as mentioned above .  Also at this point , I have not installed the pallet fork or balance which allows me to turn the mainspring with the screw , [click installed or not ] , to see the free movement of the train wheels as the mainspring winds down .
I have attached an article from N.Hacko's website that shows the rebuild for the 7S26 for amateurs . I used this article for a guide when I first got started .
http://www.clockmaker.com.au/diy_seiko_7s26/
Good Catch..Sorry  I am working on the 7s26C The title was a typo, a result of short fat fingers. I have to watch that I'll be causing more confusion than anything.
I also used the guide from N Hacko, Very informative. The man did a GREAT job documenting the process.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
