Hi Guys,
In my hunt to find new watches to practice on, I was given this watch to work on.
The Brand is Q&Q ... and it looked like a new basic movement for me to service.
Once I opened it up, I was shocked to see "NO 0 Jewels" stamped on the back.
Once I removed the movement and looked at the pivot and pallets ... this is what hit me!
PLASTIC!!
ROFL!  What a piece of junk.
But I thought I'd post it for your amusement :)
Don't wear it if you are cooking up a BBQ - it will end up dripping down your arm :D
Plastic fantastic, I've never seen anything like it in my life. It reminds me of the small plastic gifts you used to get small cars in Corn Flake packets back in the fifties. They came assembled, but would break down into about eight pieces for reassembly.
Ah those were the days.
PS Does anyone remember the baking soda submarine? It was my favourite!
Geo,  What is baking soda?
Re. The plastic watch,  I am amazed that changing a few parts to plastic can have a significant cost saving, obviously it does else they would not have bothered.
Lawson,  If you take it apart and put it back together you will have gained some practice and if it all goes horribly wrong,  no great harm will have been done.   :thumbsu:
Autowind - I'm too scared to unscrew it ... everything is under one single plate.
I think it will fly into a million pieces if I pull to the top plate :P
ps. - I should mail it to Mark to video a service on it ... maw haw haw haw
Edited by Lawson
That's just nasty - What did I do to you?
:startle:
hehe ... you know I luv ya mate :)
Just thought you could use it for a comedy video mate.
I can do my best John Cleese impression with it!
In an odd sort of way - given that modern plastics are very sophisticated these days - I'm surprised that more use of the material isn't made in watches...
Thank you Will, that's an excellent link (and sub-links at the bottom). I was wondering if casting with one of those smooth-on kits will allow to build one! I'm currently preparing to experiment with the plastic gears in the Seiko movements I'm restoring.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
