Thread size of BB crystal press? Need help.
Halvis
Does anybody know what threads the die holder of the BB crystal press uses? I got a press on ebay, and the threads of the die holder turns out to be badly stripped. The press is of no use as it is now, and a new die holder is difficult to source.
If I know the thread size, I might be able to get some sort of adapter that lets me use standard Bergeon/Horotec dies. Hopefully.
Thank you.
Count the threads on a good picture like the one you posted, and go from there.
BTW I think that no adapter exist, but with a great cost and effort, one can be made.
Edited by jdm
38 minutes ago, Halvis said:
I was hoping that if I am really lucky, I could find something like this with the right lengths and threads. Probably not realistic, but worth a shot if I know the threads.
As mentioned above knowing the threads isn't difficult but finding an adapter is impossible.
They are either M5 or M6 . On my sternkreuz press i have M6 . They are the same as on a Bergeon press?
Someone could probably pretty easy drill the old one out with a lathe and put a new fresh thread in. On the old adapter?
Maybe even clean the threads with a threading tool could help?
As there seam to be a lot of old material from the die left on the adapter?
Like this? schneideisen-hss_800x600px-2083.jpg.dbada6d5ea96329687670dd5a3d86ed1.jpg
Edited by rogart63
17 hours ago, Halvis said:
That is correct. The threaded part goes into the press itself, and the dies are snap on.
Then it's more difficult to say which thread the die has? You will have to take a look at how the thread in the press look also? Is that damaged to?
If so it could probably be saved with a helicoil thread? The adapter is more difficult?
I believe the thread in the press is steel and the die holder is aluminum, so the die holder has suffered the most. The female thread in the press is full of material from the die holder and it is difficult to get a good look without taking the press apart. I dont know if I should take it apart and clean it yet, because things are not resolved with the seller. Trying to find out what options I have.
I believe my die holder is beyond repair. There is a gap (marked in the picture) that's not supposed to be there. The plate is completely stuck and does not sit straight.Selection_055.png.f089ebe4a698572774ff189fcabfddd7.png
    • I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
