Latest Acquisition
adiorio110
15 minutes ago, oldhippy said:
Very nice, its not very often you find a second hand jacot tool complete with the bow. Do you intend to use it or just have it for decoration? Many people just collect tools.
I do have a need for it now. I don't know how often I will actually need it in the future but like you stated many people seem to collect tools and I am sure I can always get my money back if I decide to sell it.
As you know I am a complete novice when it comes to watch repair tools as it pertains to their use and value.
In fact I would like to get everyone's opinion on value.
Just want to see if I purchased right.
Also would like to know if anyone can see any obvious issues tool may have.
1 minute ago, clockboy said:
Nice jacot tool with no damage very nice indeed. I presume you found it on the bay.
You answered one of my questions as I was posting it. Can you place a value on it?
Buying right is sort of a sport to me no matter what the purchase.
3 minutes ago, RyMoeller said:
Wow, very nice.  I'm sure that will come in useful.  :thumbsu:
I'm no good on valuations unfortunately.  I do know that when it comes to swiss tools you can usually turn around and sell them for whatever you paid though.
Thanks and I believe  I can get MORE than I paid..Which is always a nice bonus:woohoo-jumping-smiley-emoticon:
Anthony
