Tell me what you think of this.
oldhippy
Nice try clockboy but wrong. If you look close at the movement to the top left you can see the steel stems of the hammers, they chime on a peal of bells above the door, the third barrel is there, you can just see it to the bottom right of the pendulum fixing bracket.
I'm giving too much away.:biggrin:
EMMMM TRICKY.  I notice in one of the pics there is a screw laying in the bottom of the case. However I think I can just see the third barrel arbour. This is a movement I have never seen before and I still don,t know how the strike works. If the steel rods strike a peal of bells above the door why has it got a conventional chiming ring?
Also how does the pendulum swing or does it miss the bracket just to the left of the middle barrel arbour.
I'm lucky I have repaired many of these movements so I know them inside out. The strike is rack striking more or less what you get in an Smiths strike only much bigger and better made. The gong is for the strike only, it chimes on the peal of bells but strikes on the gong. The pendulum swings fine, its a little miss leading but there is plenty of room.
Easy!!!! it's five thousand pounds... :P
And the case is cracked in the front, and the key hole to open the front is all worn out (not sure why you would need to open it anyways, there is a hinge in the glass so I presume you can just open the glass to wind it.
Given all that, and the hint already given, I'm going to say the clock style and movement are from different countries, like a French box with a German movement, or something to that effect (maybe dial style vs movement)...
Correct clockboy:Bravo: The movement indeed is English so is the case, the case has been made for the French market. It strikes on the gong which I've already mentioned, depending on the case and the wood it is made out of will effect the strike sound, many are very dull.  :D
I'll disregard what you said about the fusee barrels. :startle:
1 hour ago, frenchie said:
Just to make sure I understand, is there anything wrong with this clock or does it just have a design quirk (make in England for the French market)?
The only thing wrong is the description of the clock by the seller.
Beautiful massive Triple fusee French ebonised Bracket clock with Bracket
The correct wording should have been  Triple fusee English Bracket clock in a ebony type case made for the French market.
The case isn't ebony it is painted black to look like ebony, if you look at it closely you can see in places the lighter type wood. The answer I wanted was just about the movement, if I wanted the right one for the case this little game might have lasted a lot longer. I'll see if I can find a harder one next time.
This is really interesting but way beyond me.
I just test myself by putting everything on the bench, mixing it up a little, and then making myself name all the little rascals and telling myself what they are all for. I figure if I know what they are I should be able to put it all back together. LOL
Dave
This topic is now closed to further replies.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
