Seiko tuna damaged threads, HELP!
I got this golden tuna (7c46) with stripped case threads.
Does anyone have any suggestions on how to get this fixed?
I'd need to find someone that can laser weld titanium and then tap the proper threads...
I tried a different crown to verify that it is in fact the case that is shot.
On 2017-01-19 at 3:49 AM, jdm said:
It is not a 6309. See the thread (excuse the pun) on another forum, with various useful answers already.
http://www.thewatchsite.com/21-japanese-watch-discussion-forum/258370-seiko-tuna-stripped-threads.html
None of which have yielded anything... that's why I've posted about it here. The steps to fixing it are clear, however finding a person with the tools and experience is proving to be the challenge :)
With all the due respect, I think the replies given reflect well the problem, and I don't think that the steps to fix it are so clear as you think.
So where do we go from here... I'm a fan of getting things done. It seems there are only handful of ways to go forward, but again, I haven't been able to find a watchmaker to tell me: "I can fix this, it will cost you this much"
1 minute ago, morethan1 said:
I haven't been able to find a watchmaker to tell me: "I can fix this, it will cost you this much".
Maybe because it can't be fixed, or can't be fixed properly. Not everything is possible, or practically possible.
That is repairable but you need to find someone with the right skills, and specific tools for that thread, its a case of tube extraction, and then dulling existing worn threads, then re-tapping the threads again with an offset tap with the correct pitch.
I have a feeling this is one of those cases where the cost of fixing the problem would be above the value of the watch.
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
