Hello From Texas...
CapMoy
Hello
My name is Moises and as all of you I'm fascinated with watches and clocks as well.
I very much liked what I have read here and planning to stay around learning from all of you .
Have a few watches but have a very special one that my Father Gave it to me when I was 18 yrs old...( been a while ) !...it is a Tissot Multimillionaire wich has never been serviced and ticks and keeps time after 34 yrs !
Visited a local watch service guy and He said that if it is still working just leave it alone ...I know it was not a good advise from him.
Meanwhile I'm trying to practice on few old non working automatic movements BEFORE attempting to service it my self.
Anyway , I'm very glad I found this site ...
23 minutes ago, dadistic said:
Welcome!
Sounds like you have a good plan, and if you need help, you'll find it here.
Good luck!
Welcome!
Good luck!
Dadistic , thank you very very much !
Welcome to the forum!  Glad to see a fellow Texan here.  We used go to Padre Island once a year or so when I was a kid. I haven't been there in forty years.  I bet it's really changed. I hope you enjoy your practice with the watches you have.  The good thing is, if you need parts, it's fairly easy to find them in this area.  If you need advice, there is plenty of friendly advice here on this forum.  The videos from Mark are extremely helpful.
Shirley
Shirley
Hello Shirley
Thank you very much for your warm welcome!
Padre Island , my first time there was around 1989 and yes has changed ....I'm very glad have found this forum and excited o hear from the pros !
Moises
Sent from my iPad using Tapatalk Pro
Hello and welcome, Tissot movements are very good. You will find plenty on here that should help you. We like problem questions with photos it helps a lot for everyone on here,  it also helps beginners to chip in.
Hello and thank you much !
By watching my Tissot still ticking with no service at all , yep they are quite a good movmts...
I have , since I consider my self a very beginner , questions and I will post them looking forward from your advise
Thank you again
Moises
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
