Hello,
a friend of mine recently had the questionable pleasure to deal with coordinating the inheritance of a family member. There was a lot to go through, including two watches of a brand which neither my friend, I, nor the internet knows a lot about. Both seem to be very similar, however, in one case the movement was removed from the case.
We have close to no experience with mechanical watches, so I hope one of you might can provide some clues on how old they are and if they are interesting pieces?
Your help is very much appreciated,
Cheers Norbert
Hello Norbert a pic of the movement itself would help with a clearer identification probably Landeron movements.
That helps a lot thank you very much. Forgive the stupid question but is that something interesting or a very run-of-the-mill giveaway piece, despite its sentimental value of course. I'm just asking since the local watchmaker said something like is not worth the effort servicing it, Therefore it is still in question if it should be repaired or keep it in it's non functional state.
Cheers and many thanks,
Bertl
That is probably true and having a watch that works is definitely more interesting than just owning an overweight bracelet ;-)  Can you give me rough estimate what the restauration of one of these should cost if it just needs fresh oil and a cleanup? The watchmaker said something around 400€ per piece, is that a reasonable price?
I think euro 400 for servicing a chronograph is a very high price and one could find find better by shipping to some European countries, Portugal ans Slovenia are two that come to mind.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
