Dad's watch
Santa came through this year with my first real tools. I replaced the movement in my dad's watch, the one I broke when I was about 5 by winding it all of the time. I found a used movement, the exact same one that was in it to begin with. It cost me $15 including shipping all the way from England. It started ticking again on Christmas Day for the first time in 38 years. I wish dad was still around. He would be tickled pink. He loved this watch. Nothing fancy to most, but it was to him. I've been wearing it for 5 days now. It keeps perfect time, and it turns out I still like to wind watches. I'll be more careful now though.
  • Like 5
A man's watch is his only jewelry and it is irrelevant how much it cost or what brand it is.
It's personal and there's only one like your fathers and that makes it unique.
Its a bond to the past that cannot be replaced or completely understood.
Well done and enjoy !
PS. Please be kind and don't over-wind ;-)
14 hours ago, atimegoneby said:
Well done !  it must have been quite a moment to see it running after all that time,
are you going to repair the original movement ?
The original, for now anyways, will be something to practice on. I took it most of the way apart today. I'm having some trouble getting it back together right now. The escapement wheel and the (can't remember whatcha call it little forked thing that stops the escapement wheel) are both tricky to get it right it seems. Its like a puzzle. I'm sure it will come along eventually.
5 hours ago, rogart63 said:
Great done. Fantastic work.you done.  What  movement? Never seen that brand before? There is a newer watch brand called Helberg but never heard of Helzberg?
Its a UT 29c movement. I don't think they make it anymore. I bought this one used, but it works fine. The original had a broken mainspring, which I ended up misplacing, so I can't measure it to get a new one. The replacement was cheap anyways.
Helzberg is a chain of jewelry stores over here. There used to be one in Duluth, which is probably where this one was purchased originally. I'm not sure it my dad bought it, or if my grandpa did. My aunt seems to thing this was my grandpa's watch and my dad inherited it after he died. That would explain why he liked it so much.
That explains why  only jewelry comes up when i google the name :) .
I checked ranfft.de  and according to them a seiko mainspring should work? From a 66 A movement. Not that difficult to find?
The movement actually looks very much like a Seiko clone?
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&UTC_29
Edited by rogart63
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
