Witschi watch expert manual
  • 4 weeks later...
For anyone that's curious about what witschi timing machines are like the first link has demonstrations you can download. Seating kinda play with the buttons and see what things are supposed to look like.
Then there's actually four generations of the watch expert. First three generations the case looks identical except color. Enhancements added to each generation improving things. Third generation has a backlit screen which hopefully makes it much easier to see. The second-generation screen is a really shiny and reflects everything like overhead lights. Fourth-generation the machine below is basically an entirely new machine.
So first link demonstrations and the Witschi Training Course Which really is good for anyone with a timing machine.
http://www.witschi.com/en/service/downloads/instruction-document.html
http://www.witschi.com/en/group-of-devices/measurement-of-mechanical-watches/watch-expert/watch-expert.html
  • 4 years later...
Witschi timing machines are interesting versus the Chinese. If things are perceived to be out of range the witschi machine will give a variety of error messages and then refused to do anything. If it's a Chinese machine it typically will not give an error and will try to show something whether it's right or not.
Then it be helpful to know which watch are you timing and a picture of the display in manual mode when it's running as you perceive correctly.
In auto mode the machine will attempt to figure out what frequency watch you have. In auto mode it has a limited number of frequencies it will look at basically the standard. If it perceives its outside of that then you get the error message. This is where in manual mode you select like 18,000 it now knows what it's trying to time and it will time it providing its within the range of what it can do. Simplistically it's telling you it's having a problem that needs help which means there's probably some issue with the watch perhaps.
This is where it be nice to have something this machine does not have a oscilloscope. But you can also listen to it and see if it sounds right. Because anything that sounds incorrect might be upsetting the machine anyway.
Then sometimes If things get really bad you can go to rate only it won't display amplitude or beat But usually that solves the problem if things are really having issues and you still want to display something.
Then I'm attaching the PDF of the users manual
witschi watch expert II user manual.pdf
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
