Hi,
I removed the bezel for cleaning, while installing I found difficulty because of the Oring inside the bezel. Can anyone tell me , this oring should be positioned in bezel over the watch case before pushing the bezel in? I struggled for awhile and the oring crushed. Any method?
I had a similar problem and I had to change the o-ring. The old one had hardened and wasn't going in its groove in the bezel - no matter how hard I was pressing the bezel - it wasn't going to close.
You shpul measure the groove (not the old o-ring) and put the right-dimension o-ting in there
Good luck!
