Hi from the stormy Lowlands
Watchtime
Hi all,
Collecting watches for many years, mostly mechanical, I got triggered by the amazing technical knowhow of watchmovements by a close friend of mine some time ago. Not being troubled by any technical knowledge or education:), I had the opportunity of visiting my friends workshop and from that moment on I was hooked. I recently was able to buy the heritage of a watchmaker who passed away and I am now trying to sort out all the tools, parts, machines and other stuff so I can set up and complete a humble watchmakers workplace of my own. I was looking for  online co**BLEEP**s and noticed that there is no such thing in my area. Just before committing myself to the Timezone co**BLEEP**, I came accross WRT and the deal was done. What pleasantly surprised me was the friendliness and openness among the members and sharing solutions for encountered problems...I hope to learn as I consider myself as a newbee and contribute to this forum. Cheers from the Lowlands.
Hello from me. I was also very lucky after serving my apprenticeship and then my improving I was given a complete workshop not only for watches but lots of machinery for clock making. I never had to add a great deal. You will have a great time sorting all that you have out. How about posting up some pictures for as all to look at. Look forward to your input.
Goodmorning and thanks for the warm welcome. I spend a good part of the sunday to unpack the boxes and on request of oldhippy I made a few photos. I apologise for the poor quality as I made the pics with my phone. In the boxes, I found a lot of very nice items like a Bergeon caseback opener, a winder, a Witschi watchexpert(hope it still is in working order), crystal press, a huge load of tools and parts, springs, crystals, crowns, stems ect ect. I really like the old frames with the ETA parts in it. Enjoy.....
Here a few better pics of sorting the massive amount of items......the watchmakers bench is still in my storageroom, I first have to clear some space in my office for it. Most of the parts are unsorted so I started out with the sorted items and put all the rest in boxes again for checking at a later time, sorted on subject. It is a lot of fun to do......:)
Edited by Watchtime
Wow what an incredible amount of stuff to go through. Its going to take months to sort out. The photos are fine and clear. Thanks for sharing. If you find anything your not sure of just post a picture and I'm sure many on here will be able to help you out.
Welcome watchtime! Very good beginning! Most, if not all, of the tooling is already there I guess so now, with that hurdle covered, it is time to put them to the test! Good luck and please, ask away if you get stuck with any of those and/or derived projects.
Welcome fellow newcomer... I had a lot of stuff to go through, too.  I'm still going through it.  I bought my father's tools when he retired.  It was like Christmas going through all that.  I'm finally setting up a little work space to start using some of it.  Exciting, isn't it?
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
