Hello from Minnesota
Aric
Hi everyone. I am just getting started out in this new hobby. The only tool I have so far is a case opener (a cheap one). I used to have some screwdrivers that I bought at Radio Shack that were far too big, so I filed them down to size and sharpened them. They worked good enough to take the mainspring out of an old watch that I inherited from my dad when he died and then they went in the trash. I was only taking a guess that the mainspring was in what I was holding, as I didn't know what I was even looking at. I opened up what turned out to be the barrel and the mainspring shot out and into the next room at around mach 2. I don't have that broken mainspring anymore, and I'd like to fix that old watch, but don't know the size of the spring. I ordered a replacement UT 29C movement the other day. I'm going to try that approach. Other than that, I recently replaced a cheap Ronda 705 movement into a Swiss Army watch that I bought in 1992. It works again and I am thrilled to death about it. The calendar wheel is not right though. The teeth on it aren't in the right place. I'm going to try to take the old one out of the old movement and put it into the new movement. I suppose I'll need some tools first though. I don't think just having a case opener is going to cut it. Maybe Santa will bring me some real tools!
Welcome Aric,
I hope in my next re-incarnation I'm not one of your watches but the good will is noted! :)
In any case, welcome to the forum and hopefully you will find what you need to make those watches happy! Remember to ask, search and above all, look at the walk through and the tools section. I will also recommend a free Seiko class that is somewhere on the net...it is not probably the same movement as your watches but it will get your feet wet on the subject and a -- very slight -- hint at best practices so your watches have a chance. Remember, they are delicate pieces of...machinery?  :)
Cheers,
Bob
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
