Hi all,
I'm looking for an old pocket watch minute hand with square hole fitting, square hole measurement is approx 1.65 to 1.70mm and the length i need is approx 19.0mm. Im happy to buy a pair if need be. Need ot be gold. Ive checked cousins and bought some off ebay, but they only seem to have 1.50mm fitting, and its too small to file.
Can anyone help me out?
I've already checked eBay, i bought a pair but the square hole fit was too small, the mixtures of hands are probably just the same as i can get from cousins which are all round fit hands that don't fit many older pocket watches. I already have some. Thanks
What I've seen on ebay a few hours ago look like tins of old stock from a watch makers old workshop as if someone is having a clear out.
8 hours ago, Marc said:
Hi Marc, that bottom one looks perfect!! Thank you! I'll pm you, but I insist I give you something for it! thanks again.
I don't really want to buy boxes of hands that I'm never going to use, it will cost me more than the watch is worth. I've looked closely at some of the photos of these job lots and still only see round fittings. I did buy a pair that looked promising but the hole was just too small. It's a shame suppliers don't stock more variety for pocket watches.
Do you have an old watch repairer in Hull if pop along because that's the sort of person who could help you. My self I had tins and tins of hands and loads of old pocket watch movements with hands. Its no bad thing to build up stock.
  • Similar Content
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
