I live in North Texas and got interested in watch repair last winter and found this forum a few months later. I have never posted anything in the forum until now but have enjoyed all of the great information and how-to videos. I first found out about Mark through his YouTube channel which led me here. I am thankful that a resource this valuable is so accessible and informative. Thanks for providing a venue in which I can expand my knowledge and skill in what is a very rewarding hobby for me.
Thanks again,
SteveG.
Welcome SteveG. Marks videos are very good no matter what  stage you are at in your hobby. Look forward to your input and might we have a few photos of your progress watch work.
Here is a pick of a Timex that belonged to my wife's uncle years ago. It was missing the crown and the movement wasn't working. Oh yea it was also missing the seconds hand. I replaced the crown and seconds hand from a donor watch and the movement had a broken screw that I was able to replace.
The only movement that I have actually taken completely apart and put back together is a 22r belonging to a ladies Helbros but I am waiting for a donor click spring before putting it back in the case.
Hi, Fellow Texan!  I'm in Pearland (south of Houston)  Where in North Texas are you?  I might have a click spring for that Helbros, I have some old Helbros parts.  It may take me awhile to find it, but I'd be happy to take a look.  Let me know if you still need it...
Thanks Sperki77 for the offer! I just got one Thursday and have put the watch back together. Here is a pic. My neck of the woods is Forney, about 25 miles east of Dallas. I think I've ridden by Pearland a few times probably on my way to the Lone Star Rally.
Nice job! Glad you found your click spring.  You probably passed right by Pearland if you came down IH45 to Galveston.  We're only about 25 or 30 miles from Galveston.  I'll be interested to know what watch you tackle next.  I haven't done much yet.  My son is building me a little apartment behind his house and we don't quite have it done, so I'm "chompin' at the bit" to get my little workshop area set up.  Right now, I can only change batteries and adjust bands and stuff.  When I get set up, though, I'll have what I need to fully service a watch.
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
