Having recently purchased my very first vintage, see below, I am curious to when it was manufactured but with no paperwork with the watch its tricky.  Does anyone have any information on the brand Reporter?
29898775271_f1cb4a02df_k.jpgDSC07437 by Micky Aldridge, on Flickr
The watch was purchased from Italy, and the day wheel is in Italian.  I have found a similar watch , different brand however, also in Italy, almost identical but with a blue dial, I cant find the listing at the moment however..
Found some info here..
http://forums.watchuseek.com/f2/reporter-watch-brand-158986-2.html
And here http://www.inghirami.com/brands/reporter/
Edited by SSTEEL
More info http://www.reportertime.com/Homepage.aspx
Quote
The cult movie “Professione Reporter” starring Jack Nicholson has been the source of inspiration of this brand: the image of an international man
Reporter Collection is characterized by a strong message, enhanced by a complete proposal of accessories.
Reporter brand was acquired by Inghirami Company in 1994.
Film was released in 1975, so that gives me a rough idea of when my watch was made, probably late 70's.
Edited by SSTEEL
Watch size can be an indicator of recent times. The 35mm (including crown) dominated for a long time. It's hard to say from a photo but if you have an average size wrist I would say mid 90s onward because it seems quite large
Sent from my SM-G920F using Tapatalk
I found out its 1982 [emoji4]
Size can only be an indicator but not conclusive. Here's my swatch. Bought in 2007 I think ? It has a 37mm case. Domed crystal as opposed to flat and fitted with a ETA 2841-1 movement.
From after that time watch size went bigger to Coco the clown size, as today7cb804422bc900e64a9ded20be6b5ef2.jpg420e4974148e038ed5ca473ec70617cf.jpg
I've another watch for you. This is my Omega. It's a classic 32mm case (35mm) with crown. It has a Flat Crystal as becoming more popular from the mid eighties. It's fitted with the Omega 1430 movement (ETA 255.111) Base movement. This watch is so comfortable to wear you need never take it off. The watch dates from 1984.
Beware though as vintage watches can become VERY ADDICTIVE !!!c931f1bc22c881138ac53345d025b829.jpg1c9a400208ba2312045e1e52122715d3.jpg
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
