2824 keyless problems
AP1875
So this morning I serviced a Chinese 2824 I have. I completed it with no issues (or so I thought) and started to give it a good wind to check the power reserve etc when all of a sudden the keyless was just spinning freely when trying to wind.
I put it into the quick date change position and all ok.
I then placed it into the time setting position and it was ok.
So I took the cover off the keyless to check it out. I've found that when I put it into the winding position the sliding pinion is not moving close enough to engage the winding pinion.
I rebuilt it and now it will wind and quick date change but I can't set the time.
The yoke determines the movement of sliding pinion (which is seated correctly in the pinion).
What controls the yokes movement, it's as if it needs to push further?
Any ideas appreciated
So as I removed the spring this is what I see, the setting lever has jumped on top of the yoke. Now I don't know if this had happened as I've taken it apart but I think that would explain the reason why I can't set the time as the lever wouldn't be able to push the yoke/sliding pinion all the way back (please correct me if I'm wrong).
Now I just need to work out why this is happening, it should all be held in place.
Cover plate back on.
As it was in the wind position when it went back together, winding was ok. Moved across to date and time positions all ok. Tried to place back into wind position and the same problem - sliding pinion won't engage the winding pinion.
Ok, so when I adjust this screw for the spring that seems to affect whether it will engage wind or time set.
Tighten it right up - no wind function
Loosen it off - no time set position being achieved
It's half way between now and all functions work [emoji848]
Would this suggest the spring is damaged bent or something else to you guys?
(I'm really sorry this isn't all in one post)
(This is the screw I adjust)
It sounds like you may have over tightened that screw. remember we are working with very small tolerances here have you checked the setting lever spring to see if the plate around the hole has bent or deformed in any way causing it to pinch up to the yoke when tightened.
Look closely at the ends of the bridge screws (which screw in from the dial side) there should be a short one which goes where the yoke/ spring fits. if they're in the wrong place , the longer screw will stick up and interfere with the movement if the yoke.
HTH
Anil
HTH
Anil
This is a very good point, I didn't think of that. From looking at the picture that would be the screw just under the crown wheel. I think I have the correct screw but maybe when I tighten the screw from the spring right down it catches...
No need to hunt for a correct screw, Chances are its been swapped around. Remove them one by one and see if one is shorter than than the others, not only the barrel bridge but also the train bridge and balance cock screws as they're the same type.
rgds
Anil
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
