CONFESSION TIME
TimFitz
I bought a nice new roller table remover to aid in replacing roller jewels.I have some old Ballance wheels with tables attached to try my tool  on. Then I watched a great video by our founder, where he used this tool to remove the table.I was very impressed & confident.
I took the shiny new tool , carefully slid it between the balance wheel & roller table, checked (under magnification) , put the whole thing in a plastic bag (so not to lose ping the table across the room) , then gently squeezed. Nothing happened, so I squeezed a bit harder, still nothing. So instead of using  my brain & watching the video again to see if I had it correct. I gave a mighty roar & squeezed like "Mean Mountain Dean". It popped right off the staff. I patted my self on the back saying "Your The Man".
It's then I noticed the balance staff was cut in " twain " as they say across the pond. What could I possibly done wrong? Perhaps it was a faulty old staff ? So you have two more old Ballance wheels in the box, try again? Ping there goes another one. It doesn't take Alan Einstein "sic" to figure out it must be me, not the tools or staff.
After re-watching the video It dawned on me, I had the tool upside down " (duh) "
There I confessed & feel much better. You can bet, I won't make that mistake again !
Edited by TimFitz
error
so where is Marks vid using this tool and which way up do you use it then ?
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
