Magic Roller Remover
jdrichard
looks like portable version of stacking set roller remover. Place balance in the middle piece, roller table up (I suppose roller table should be placed on middle die to allow rest of the balance to fall down), and gently push down with punch, checking if balance pivot in secured inside punch hole.
I actually found a similar item in the Chicago Manuals.1a7fea54308e90a46e5f65598239b71e.jpg
Sent from my GT-N5110 using Tapatalk
Nice and simple tool. I need to make one roller remover as well.
But how can one set the jaws distance? Those need to be far from each other to insert the balance wheel first and then tightened to grab the roller table.
I can think it is working like a lathe chuck, tightened with the srew at the bottom?
Szbalogh,
if it helps, here is the roller remover stump from my staking set.
As you can see it's spring loaded, the spring pulling the conical base of the jaws down into the conical recess of the main housing, closing the jaws. To open the jaws you just press the protruding button at the base of the unit, pushing the jaws up and allowing them to open You insert the balance, release the button allowing the jaws to close, and install the whole lot into the die plate of the staking frame. You can then use whatever stake is most appropriate for the job in hand.
Szbalogh,
Thanks Mark. So when you tap on the punch, does the balance then drop with the whole lot and the table stays put
That's pretty much it.
The tool supports the underside of the roller table and you push the balance staff down through the table.
This particular tool has limitations though, I have yet to work out a way to use it with 3 arm balance wheels, and I'm not sure that 4 arm wheels would work either, so for those I have other tools.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
