Need help opening a Vulcain Cricket
Watchmaker gave me some info on this a couple of years ago, the brands may be connected, I'll see if i can find it Scott. https://www.watchrepairtalk.com/topic/22189-ackro-watch-history/ -
How about using a magnetised screwdriver for picking-up and fitting screw, then run the assembly through a demagnetiser. I know magnetism is a no no, but this method is less fiddly, and has worked for me on several occasions.
Find a plastic tube, cut longer than the K&D, put your tools etc in it and hold both ends. The plastic shouldn't have any effect.
