Hello from Ottawa, Canada
MilTimeCan
On 9/3/2016 at 4:24 PM, Khronos said:
Welcome!  Yes, I so agree about Mark's videos!  What a guy!  I thirst to be able to run a pair of tweezers like he does.  It's so much fun to see a master craftsman work.  Beautiful!
oh, yes. sooo true.
I am in absolute awe with the ease which he moves watch parts around, it's like watching a ballet.
