Password Changes
Anybody else received a mail from "vertical-scope.com" advising about data theft from our forum.  It does not worry me too much as most of my info that has been used on watch forums is fairly easily obtained anyway but presuming this is not spoof at the minute a change of password to 10+ characters with upper and lower case plus characters and symbols may be prudent. I am still looking into it though as I thought the provider was Invision power services inc.  I may have received spoof mail
Vic
Edited by Vich
Additional info
I don't usually open those email since they can set up (once opened) some sort of key logger (in the background) and then you will be giving out your password for sure. Maybe it was a hoax....
No it was not an hoax. Vertical scope' database (owners of the biggest watch forums) has being compromised and they were forced to a global password reset.
Fortunately it takes more than just opening an email to install a keylogger.
    • I've remembered something I had forgotten.  I've come across Dennison before but forgot all about it as I'm never going to use the units.  Maybe we should start a  thread on obscure units of measurement.
    • Learned a new thing today! 🤓 Looked this up and found this informative document: Watkins-MainspringGauges.pdf
    • Correct one dip is expensive when the chemical is purchased as " one dip " which is why it is mostly reserved for these two small parts as far as information tells us it is mostly tetrachloroethylene. I use it bought as perchloroethyl used in dry cleaning processes, i cant say I'm overimpressed with it though it appears to me to be shellac safe. What may be a better solution for hairsprings is a high lab grade of pure benzine.  IPA is mostly used as a rinse and water displacer and yes it does have the potential to dissolve shellac, personally i would not buy anything that has significant water dilution so 99.9% IPA is the way to go. And lastly the part you are cleaning dictates your choice of cleaning brush, delicate parts like a hairspring requires the finest artist's brush you can find. Plates and bridges can take a little more scrubbing, but always check to make sure the surface is being unharmed. And dont forget a stick of tip benzine soaked correctly shaped pegwood is your mate set up for cleaning dirty jewels and removing stubborn dried up lubrication.
    • Den / Dennison is a unit measurement of size this is actually a mainspring gauge . I haven't heard of a pivot been measured in Dennison before.  Though the small thickness gauge is  usually supplied with a Jacot tool and is more accurately known as a pivot destroyer.
