Elgin Mystery Dial Line Up
diveboy
Here's the complete mystery dial line up from the horizon line of Elgin.
q9MORNH9DTY9JbPJdaeU04CDk6swGovoE6dwY6Ib
Left to Right
7620 - Lord Elgin Futura Black Variant
7625 - Lord Elgin Briarwood
7510 - Lord Elgin Cranston
7516 - Lord Elgin Stratford
3 years of serious hunting in one picture.
Edited by diveboy
  • Like 7
I like!  Interesting, because I was just reading about late 50's early 60's Elgins, and the Durabalance and other features that they were coming out with at the time. Now there are even more watches that are on the must have list!  Arghh :wacko:
  • 6 years later...
The 7620 with the black dial has been the only one I have seen besides mine. Could you please tell me a little bit more about the watch ? I looked up the serial number and it came back that it was made in 1945. But some things they had wrong about it like it said it was a 17 jewel and it's actually 23 jeweled. But if you could please help I'd be greatly appreciative.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
