Ive got a rather nice Eterna Matic 2002 in for restoration with an original ETA 2824 movement ( high finish ), only issue is the Yoke ( Part #435 ) is snapped and i can not source another from anywhere :(
Ive got the technical documents but im still a bit unsure about interchangability, so my question is.......
Can i use 2824-1/2824-2 yoke ( or all keyless parts ) in place of the broken parts ? ( given the design is different )
Simply put is it possible to update the keyless works to say 2824-2 ? Im hopeful but if not i will be forced to cry man tears :(
Any chance you could post a pick of the yoke as I think I have one in my spares. Ive got plenty from 2824-2 etc but just scraped a few older models with older keyless. if i have one you can have it with pleasure.
Edited by DJT2
spelling
Thanks for the responses guys ( and your generous offer DJT ), i rather stupidly forgot to check my ETA cabinet for spares :unsure:. ( shakes head in disbelief )
Turned out i had one of the older yokes all along in a 2836 service tray, silly of me to presume i didn't have one and not check.
Got me in quite a panic ( ohhhhh noooooooooooo kinda panic  ), but shes all good and ready for finishing , new glass is gonna be a pain to find to fit that inner bezel, but in the mean time i will seek out a new skinny strap.
Lesson of the day, CHECK your stock first and do not presume lol
MrBeat
Looks clean as the day the factory booted it out the door. I'd say, put a classy strap and ready for listing :)
Oh yeah the movement is now spotless not a scratch or mark in sight. A Hirsh strap is on order and im hoping one of the acrylics im going to be ordering will be a good fit with that inner bezel ( the original has a chunk missing :( )
Timings pretty good too +- 8 seconds, but the stem set & winding now works which is the main thing :thumbsu:
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
