I am trying to help a friend of mine.  His glass crystal on a fendi watch broke.
I think the case number is 013-695.  See photos below.  Where can I purchase a replacement crystal? And what else do I need to install the crystal? I pressed the broken one out.  Did not have any glue. There is a white plastic gasket in the metal case
Many people on here use this supplier https://www.cousinsuk.com/
Give them the name and number you have which might help. Measure from 12 to 6 with a gauge to get the correct size just in case the numbers are meaningless.  You will need a watch glass fitting tool. There are many to choose from.
This type  or the little blue type in the picture which  Bergeon supply, I have been told the Chinese do a much cheaper one and is just as good. I think ebay have the cheap ones.
Edited by oldhippy
