Tips for bending a second hand back
Have a Seiko 9139 that wont really make it to the middle. There i a half second wrong. It bugs me Have tried to bend it but it gets back in the same position again. If i can hold it still i would work i guess? But how should i hold the tail and the pivot area still som i can bend the long second a little. Under control.
The proper way to fix this is:
1. Remove the second hand
2. Run the chronograph.
3. Stop the chrono
4. Press the chrono reset - this will zero the mechanism by striking the hammer against the chrono wheel heart piece
5. Support the chrono wheel pivot on an appropriate tool - either a special holder for the movement or something like a bergeon 5409
6. While firmly depressing the reset lever, install the second hand exactly at 12:00 and press firmly in place
Holding the reset lever will keep the chrono wheel locked at 12:00 enabling you to get the alignment perfect. It is critical to support the pivot/jewel else you are likely to dislodge the jewel.
3. Stop the chrono
Have a holder for supporting the jewel so that is not any problem. The second has a fixed point where it sits at the pivot. I just wanted to bend the second a little to the left making it more straight.
58 minutes ago, sstakoff said:
I have also used a seitz jeweling anvil with appropriate pusher as a platform to support the jewel/pivot
Have a tool for the job of supporting the jewels . Have to remove the oscillating weight but that is no big deal.
I will keep it as is at least for now?
Have you checked to see whether or not you can rotate the heart piece on the pivot? Unless the second hand is actually bent incorrectly I wouldn't want to bend it. Doesn't seem like the correct repair.
On Seiko 6139 you can't rotate anything. But i will figure something out? Have some ideas i will test.  Like having two supports and laying the hand on the side and pressing a little in the middle?
Get two very small diameter nails and hammer them very closely together into a block of wood leaving about three millimetres sticking out.  Place the second hand face down between them.  Now starting at the tip end of the hand between the nails, gently push or pull the hand to ease out the bends slowly working your way to the centre tube.
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
    • Hi. That explains it, done that myself.  Leve the movement open with the back off and battery out for a few days in the sun and let it dry naturally, re fit new battery and try again if  it is not successful the circuit block may be toast,  Better if you can get the movement out of the case for drying what is your location
    • Thanks for that. He's worn the watch daily for the last 20 years, he said he didn't even think about it being on his wrist, because it's always there. He had a shower and when he got out he noticed the crystal has condensation on the inside. I may have exaggerated when I said it was FULL of water 😅 I removed the movement from the case last night and there's no sign of water on the coil or battery, however the dial has dried water spots on it. I'm not sure about stripping the movement further, I've never done anything with a quartz movement. I tried looking for a donor movement but they seem to be practically non existent. Even Jules Borel doesn't list this movement in their parts catalogue
