Pinged an end jewel....what now?
So, I've just pinged the lower balance jewel from a Peseux 7066 acrooss the room. Can't find it (I'll keep looking)
How do I go about finding a replacement? Buy a bunch of jewels, and hope one fits? Buy another movement and hope it has the right jewel?
What would the experience among you suggest?
I had the same thing happen to me with a Longines movement.  The cap jewels were clear (as opposed to pink) and one went missing when I soaked them.  Faced with he same question as you I went with the most economical solution which was a second hand movement.  I did consider a bulk set of jewels from a supplier as that seemed the only other option without the jewel in hand to measure for dimensions.
The bonus to getting a second movement is that you'll have other replacement parts available in the event something else crops up.
I should point out however, that rubies fluoresce under UV light.  I have a strong LED UV flashlight at my desk for those occasions where a jewel is dropped on the desk but out of sight.  It's saved me once already.
Yes, it's the lower incabloc jewel. £12.75 is more than the watch cost (£11)
Where can I get a cheap set of jewels?
It measures about 1mm. I know .90mm is too small, and 1.15 is too big.
this is the price for the complete bloc, may be you can buy only the cap jewel
from a junk movement with the same incabloc
Well, even if the watch cost that much, it's likely worth more once serviced. I have 4, 1mm cap jewels, so you can have one. Postage to London (I don't know where you exactly are), is around $3
I also have 1.1mm cap jewels, so I can give you a 1mm and a 1.1mm.
I doubt it will ever be worth more than I paid for it, but it was my own stupidity that caused the issue and I will fix it.
Thanks for the offer of the jewels, very generous, but I think I'll keep a look out for a scrap movement, that way way I'll know it's the right jewel, and I'll have a spare movement as well.
Sweep and sweep...get a small dustpan and scrutinise the dust with a loupe.
Put the watch away...you'll be surprised that the jewel will show up when you're working on something else.
I keep a 'missing-person's' list on my desk...this is so I when the broom turns up an unexpected part I'll have some idea of which watch it comes from...
Anil
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
