English Pocket watch movement?
A friend of mine need some help. This watch has a broken balance staff. He has been to two different watchmakers and none could help him. So now he going to have a go at it himself. But we nor the watchmakers could tell the movement. They guess it was some kind of AS 137 ? And the other said an English movement?  Anyone recognize it? Sorry but this is all the pictures i have now. If we can remove the balance how should we measure the pivots if we haven't got any? Both broken :(
Edited by rogart63
29 minutes ago, oldhippy said:
A few questions first.
Do you have a good lathe suitable for watch work and have you turned anything.
I am not going to do it. Just helping out as good as i can. I think he is going to see if he can remove the balance staff and see if there is something that could fit. We have some Swedish forum members that are skilled workers at the lathe. But have to remove first? My friend has all the tools he needs to put the balance back again.
He also has some old balance staffs in his drawer.
Edited by rogart63
You have to remove it. Its so tiny that simple measurement wont work, you have to try the parts on the working piece while turning. Moreover, if the broken one is available just use that for measurement! Place it next to the working piece. There are a few videos on youtube how to do it.
I have the same problem like your friend. Experienced with turning the balance, had 5 tries and the last one is acceptable by size but forget to undercut the balance shoulder. Now i need a lathe to be able to turn between centers to finish the pivots.
You can start from HSS material or from mild steel and carburizing it before pinion finishing.
Let me informed on Your progress!
1 hour ago, clockboy said:
If you can identify the movement & size then you might be lucky to just purchase new one. Try  from
http://www.balancestaffs.com
Yes, thats the easy way. Sadly my movement has no signs just a 419 number under the balance. I have a guess for the caliber  but dont want to risk it. Turning a new one must be fun and a great challenge :)
Here is what i have turned @ 0:57.
Looking ugly but its carbon powder baked on the surface @around 800 Celsius. Remember, the whole staff is only 3.5 mm long and made it on the Dremel lathe :) Somehow i need just to finish the pinions.
Since the balance wheel is riveted on the staff, it is removed usually by cutting the staff under the wheel not by forcing it out. Hovewer, i forced out mine as well :huh:
Video 1 for balance staff turning:
Video 2
https://www.youtube.com/watch?v=M6svZzTBIeM
Edited by szbalogh
2 hours ago, oldhippy said:
Has the balance wheel center bar split because your second picture of balance only looks as if it has. If so you are going to need a complete balance.
That is probably the light that causing that effect . There is no split in the center bar. :)
Two good catalogs that are a must for identification are these two. Most old watches this includes pocket watches can be identified by there keyless work so you need to take of the hands and dial and upload a photo. You never know someone on here might be able to help you out if they have these catalogs which are
Flume identification movement catalogue
Besrfit identification movement catalogue
You see these come up on ebay if you are lucky buy both.
I hope this helps.
Interesting thanks clockboy and oldhippy. I will take a look at that. Have some more pictures. And my friend is measuring the movement right about now. So we can see what ligne it is?
It has a kind of strange looking keyless work. Perlage and a reed's adjustment on the balance bridge.
5 minutes ago, rogart63 said:
Asked David at vintagewatchstraps? But he never seen that movement before. And he looked through bestfit and smartchild books. But can't find any similar movements.
At that time many watchmaker companies bought the movements and made some modifications to it. Like mine Stowa above. They have different shaped bridges, keyless works or finish, but the critical parts are the same.
Try find the movement from the other end! Measure the broken staff exactly, find similar ones in the database and finally check the movements associated with the possible staffs.
Anyone have the Ronda CD. Where you can search on sizes? Thinking of  buying it from redrosteruk . But i don't have a cd player on my computer so should need it on a memorystick. Is it any good? Is it worth the trouble to fix it over to memory stick?
4 hours ago, syfre said:
Ronda staffs by size is in the download section of cousins uk
Thanks to all for your help . szbalogh and syfre . Did take the measures i had an looked on Cousinsuk ronda staffs. Found one that was as near as i could come. It was a Postala. Googled postala and hit the nail riight in the middle. Made my day:Dhttp://bdwf.net/forum/showthread.php?t=72531
    • I'll go halves with them John , we can share it 😉
    • Besides locktite Nev, is there anything random that you use to fix in the pivot ?
    • Thanks Hector, I do think though that the problem I am experiencing is specific to Miyota movement in general and the 6T series in particular.  When you describe putting the bridge you are talking about the train wheels.  The problem here is that under that same bridge you have the 4 train wheel, the barrel, 2 extra winding related wheels and the center sweep pinion.  I can mostly put them in their holes but 2 of those (the 4th wheel and the second pinion are completely under the plate so I can't nudge them in the right position.   I managed it with a larger Miyota 8200 series but with the smaller 6T15 it is even worse. Anyway, I'll retry tomorrow evening or this week end.  This evening is going another rock climbing day (going from very light pressure on tweezers to much more force going through the fingers, although in climbing we also want to use the absolute minimum grip which won't make us fall to save the muscle and be able to climb longer routes). to add insults to injury, if you read this thread from the start, I initially messed up the disassembly as I couldn't detach the rotor.  I normally (and I think I did this time too) put all my parts in their individual compartments in the part tray and I am doing my best to be very careful about them.  But in the week and a half it took to figure out how to detach the rotor I somehow lost the screws from the bridge.  I have a few others which will be needed later.  I know they are reference 922-600 but I couldn't find what it means in general term so I don't know if I can buy replacements or an assortment of screws and replace those 2 by others.
    • Something that can happen with a lyre spring, the back of the arms can bind against the shoulders of the chaton cut out where the spring is fixed in when the spring is lifted out of the way. To stop the spring bending or breaking it needs pulling forward slightly before lifting so it clears the edge of the chaton.
    • One way is to file it by hand. Good file with sharp edge is needed. Another way is with the aid of milling attachment. There is one more way, thyat is really only on the lathe, but the arbor has to be attached perpendicular to the axis of the spindle. Will be easier to show pictures than to explain this. I must say 'Good night' as my wife is now awake and is roaring when I get closer to the computer...
