Cheers mats!!
And good sunday for all of you that is on this side of the globe. Im just started this fascinating interest for watch. And especially Seiko diver from 1960 and forward. So I have been on the web and serching for  "the real deal". And on Ebay, I found this seller with the ID = loyswatch, and he has this records for over 1000 positive trades over the 12 month. So Im wounder, if anybody have bought something from him/heard somthing about this guy, and have some comments on this??
Looking good . But if you are looking for an original Seiko you should look elsewhere. All the watches i saw where modified in one way or the other? There are many Seiko as Seiko had a factory in the Philippines.
12 minutes ago, arkobugg said:
Thanks rogart63, but where to look elsewhere ? Have any good suggestion?
Depends on what you look for? A nice 6309-7040 you could probably find at Ebay or SCWF. A 6309-7290 would be a little cheaper. This is a good example from speedtimer where they say if it's original parts. Nice patina i think? But not all agree on that?http://www.ebay.com/itm/Seiko-Turtle-Divers-6309-7040-automatic-Serial-nr-510119-/131667489310?hash=item1ea7fe721e:g:vvAAAOSw7FRWYIsQ.  With some new o-rings you could make this watch waterproof again.  If you are looking for a original watch you should look on thewatchsite or wristsushi. There you have some tradingforum .
Edited by rogart63
ID = thewatchcollector.
Most of his stuff is AS-IS and will require some work to get running.
Loy does not have a good reputation among collectors.
My first choice is a Seiko 6105-8110 or 6105-8119
Tried to searche on Ebay after thewatchcollector, but didt find any, could you send me  a link..
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
