Image1461989030.274300.jpg.690480a9d314bImage1461989048.600434.jpg.4226c8f5ab9ca
I have a broken jewel in a 2824-2 ETA. a screw got loose in the movement and busted a jewel. I took it out, but it was demolished. I need to know if anyone knows the measurements for the jewel? I also do not have a hole measure. What do I do? It is the fourth wheel!
Also the top escape wheel jewel was out of whack so I straightened it, but I think I would feel better if I just replaced it.
Does anyone know if and where I can find the sizes of these jewels? I think it is such a common movement that they would just have the sizes listed somewhere.
I think it is the fourth wheel? Out of the four jewels on the drive train plate, it is in the middle.
Wouldn't it be easier to find a new or better train wheel bridge.
Edited by rogart63
I tried that with jborel, cas-ker and cousins, but they didn't have one. I didn't try ofrie because I figured the same. I haven't tried the bay yet. I guess I'll try that!
Pm me your name and address with all the parts you want for this movement and I will send you what ever you need, got loads of parts for these in my graveyard box.
Dang it! I ordered it from eBay before I saw this post! Crap!
Thank you Tik! Definitely next time I'll take you up on that!
No problem, if you find anything else you need when you get into it just let me know, are all the wheels spinning true and have you double checked for scored pivots on the train wheels, especially the wheels with cracked jewels?
Thanks for the reminder! I was going to when I pulled the jewel out originally but forgot! I will keep in touch!
How are you getting on with this watch, was everything you needed on that movement I sent you, I made sure the hairspring was flat and centred before it left, hope it was still OK by the time it reached you!
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
