Call me old-fashioned, sour old man or whatever you want to ..
But there is one thing that ls me or rather disappoint me.
When making a fine fine article with a lot of illustrations then it is a shame that you can not hold on to the good old virtues of placing text right under it to illustrate. Open any book that is the descriptive text below the image. It has always been and it should also remain for ease of reading.
In this and many other forums have begun to put text over the image or artwork and even the same distance to the next image. This makes it very annoying to read and in particular to understand ....
I know that the software in forums and blogs often makes it difficult to place the text right under the illustration, but if just the description under the illustration, so we've come far ...
Maybe it's just me, sorry
Google translate is my friend!
Hi maclerche - the Reply box in this forum (I'm looking at it as I type) has a spacing option - left, centre or right - for placing pics and text into the reply. I would have thought it fairly straightforward to centre/align your pics and text as you feel fit, using a combination of place options for the pic and spaces for the text like this:
Screen%20shot%202016-04-21%20at%2016.26.
A screenshot centered
                      A screenshot placed right with centred caption
A screen shot placed left with centred caption
Just my two-penn'orth!
Will
I think what the OP was getting at was not alignment, but that it's not obvious with the new forum software how to insert a picture in-line at all. If you just drag files onto the paperclip or choose them, they just get tacked onto the end.
True - but it's still possible to alternate - say - text with pictures and set the alignment. It's also possible to edit the picture immediately after creating it - by double-clicking it - and change the size and alignment of both text and pictures. Here's a picture:
Hamilton 747.gif This was originally 750x750 px when I inserted it into the post - I double-clicked and changed the aspect to 75x75.
Here's the pic again: Hamilton 747.gif resized and then centered.
All images in the post are the same picture from "choose files" option...
Hope this helps!
Cheers,
Hamilton 747.gifWill :D
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
