Bergeon Case Knife ? possibly not
Vich
Whilst looking at the Bay I came across this - http://www.ebay.co.uk/itm/391408533598
Now the item in question comes from China apparently, the initial picture  is pretty ordinary - Watch Knife 1.jpg
But the surprise comes in the next picture - my curiosity got the better of me as I have not seen a clone like this sporting the actual name it seems to be illegal if not genuine. Perhaps I have wasted £4.95 but I just want to see it up close.  Or are Bergeon sub contracting to the worlds largest steel producing nation now - the accredited version of this item sells at around the £20.00 mark though I have not shopped around.  Wouldn't care I don't even need another case opener but the folding penknife may be handy - boys and their toys!
Cheers,
Vic
with the quality of that printing, i'm going to go with replica!
I have quite a few of these collected over the years and they are always useful. I like to keep them in various states of sharpness. E.G. I have one that I have sharpened almost to razor sharpness with a very thin edge - very useful for opening gold case snap-on backs. I have another which I have made extremely dull which is better for thicker steel snap-on backs. I have another I use for taking off watch straps.
And another I use for cutting slices of apple when I need too :D
Hi Mark,
I am still recovering from the beer festival last night and my bay browsing was probably ill considered anyway.
I agree, definitely dodgy, will probably turn up with rust spots but curiousity got the better of me.
Apples eh !  I think you use them to make Cider.
maybe it will be worth the £4.95 I have paid after all.
Cheers,
Vic
I still have one of my case knife openers and mine has Zenith on it  same colour same fittings mine was free because we stocked Zenith watches. smiley-face-laughing.gif
Lol. Yes. Like my Rodania one. My oldest and most favouritist. :)
Just thought I would advise that the knife has arrived and I am quite pleased with it - especially at that price.  there is something odd about the packaging though as you can see it did not arrive from PRC but from Zurich ? Postage was free as well.
The knife has no identifying features but is solid enough to do the job well and looks like anodised steel.
Cheers,
Vic
i was reading an article the other day which really p*****d me off.
About pocket knives of which I have a large collection. For years I've carried a small Victorinox whenever leave the house and wouldn't be without it.
Another Swiss brand is Wenger but I just assumed that Victorinox were better.
It now appears that they are both made by Wenger. So much for my Victorinox obsession.
To add insult to injury I found out that Bergeon knives are also produced by Wenger and badged to suite but still with Wenger on the knife blade.
I found that my Omega case opener carries the Wenger name and trade mark.
I would say that any Swiss made case opener will be made by Wenger and any without the Wenger trade mark will be from China or similar.
So much for the wonderful Bergeon brand. Do they really make anything themselves. :mad:
Edited by Alaskamick
    • Does it say 17 jewels on the dial or on the movement ?
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
