Wrong tool for the job
Tonight I ran into a problem winding a left handed mainspring. My mainspring winders are all right handed winders. Luckily, I have two winders in the size I needed. So I wound the spring into one, then carefully pressed it out into the other. Then into the barrel. Not ideal, but it works in a pinch.
I remember that Marc posted a simple but clever (to me anyway;)) suggestion last year on this. Have a collection of washers in different sizes, then it doesn't matter which way your winder goes. If you need to change orientation it you can transfer the mainspring to a washer, flip it over and press out. Saves having to have spare winders or buying another set going the other way.
Stephen
Stephen
That is a good idea, too!
That is a great idea. Thanks
Stephen
Don't understand
14 hours ago, jdrichard said:
Don't understand
Simple. If you only have a right handed winder but your spring needs to be wound left handed, wind it up right handed but instead of installing it into the barrel, install it into a washer. Flip the washer over and then press it into the barrel as you would a new main spring. obviously the hole in the washer needs to be slightly smaller than the inner diameter of the barrel.
Got it, thanks
Moved to Tutorials & Information section :)
Good tip - thanks for sharing.
9 hours ago, Folkvisor said:
I recently found this on YouTube: Servicing an IWC FA Jones watch.
I can't find it on the videos on this site. Just wondering if it's there or will be put up soon. It's a beautiful watch and a very good video.
Dave
Lol - very big change in topic from "Wrong tool for the job" apologies to the OP.
@Folkvisor, I have added the video now:
Your solution to reverse winding was simple but affective like all good ideas.
I'm supposed to take the mainspring out of my 2836-2 movement by hand, clean it, lube it, and put it back by hand. I can see all sorts of problems with this. One of the main problems is that my hand would contaminate the spring with the sweat/oil from my hand and make it susceptible to rusting, etc. So, I'll buy a winder before I attempt this manoeuvre.
I have attempted to wind a couple automatic wristwatch mainsprings by hand. But never been successful. I can't get more than a few coils wound in before the while thing explodes in my hands(twss). I gave up trying and found a cheap set of used winders on eBay.
But what about the opportunity to exercise the very thing that makes human hands such miracles of evolution - the ability to apply immense forces (clamping that damned bridle against the barrel wall) while dexterously holding a 10mm object and a loose, floppy spring end, and simultaneously winding and guiding the spring into the (virtual) center of the spring? Only to realize that you've wound the thing in backwards...
So on the other hand, humans also invented tools so that work was easier and more productive.  Buy the winder, Folkvisor...
Drat, can't "wriggle out of the crushing grip of reason" (Calvin and Hobbes quote, for those that are fans).
When done with the barrel on the bench is not that difficult. However as mentioned before it's better not to to manipulate the hairspring with bare hands.
Edited by jdm
You make hand-winding sound almost appealing - or was that appalling? LOL
I even read Calvin and Hobbes in French; everyone needs a hobby...
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
