Real Or Replica?
A friend of mind found a Tag Heuer CW2113/HF7209 watch in a Park and thinks this is a real TAG, how could I tell if its real or not?
Its a gents crono, with 3 sub dials at 3 6 and 9 o'clock, with a date window at 5pm.  It has the TAG emblem underneath the 12o'clock and the back of the watch is engraved with the TAG logo, above that is the words "Swiss Made since 1860"
and below the TAG logo is the numbers  CW2113  HF7209  and Water resistant 30M.
The back of the watch is held on by 4 cross head screws  its very heavy, and has a hidden clasp to open it
If this is real what would it be worth?
not identical to yours but take a look at the differences for a similar watch
http://uhrforum.de/tag-heuer-monaco-cw2113-t38309#post508280
note the engraving on the case back, the tag logo is richer, & the numbers are engraved slightly lighter. And it has a beautiful mechanical movement in it. The one you have is a replica................ BUT this could be a very sentimental watch to someone, maybe a recently departed left to a son or daughter. Would be ashame to pass it on for a fast buck.
Hand it into the police & if its not collected it will become rightfully & legally your friends. If its collected it might be with some relief to the owner. (imo)
Edited by Lee
Thanks for your replies and I am sure that my friend will be handing this into the Police, he wanted to see if it was real so that if there was a reward he would know who to contact and let them know where the watch was, and he knew that I was interested in watches and asked me.  I know that there are really good replicas around so I asked here where I knew I would get honest answers.
Thanks I shall give him the news. :)
David.
The serial number matches to the tag monaco, but this isnt even the right watch. I agree with you that the replicas have come a long way, but this was not one of them. If it were, he may have still gotten a reward for it.
Too bad.
  • 1 year later...
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
