Repeater Advice Wanted...
DJW
I've been interested in buying a repeater for a while, but l'm starting to get serious about it now. I know that I should avoid any watch that does not function properly, Thinking that I can get it running. But, even if I find a properly running example, what are the most important things I should be aware of? BTW, most likely will start out looking for a quarter repeater to keep costs down. Also, I'm willing to spend about $1k for a good runner.
Probably buying from a reputable and well known source would be near the top of the list,  even if it costs a bit more.  I do not know enough to be able to offer any advice on repeaters except it would be nice to own one.   :thumbsu:
Yeah, I've been trying to read up on how they work and what to look for when buying them, but there's not a lot of info regarding them. All I've read was avoid any repeater like the "Plague" if it does not work correctly!
I Also read to look for ones that are "Jeweled to the Hammers" - Usually a sign of a higher quality watch.
Does anyone own one? Or, have you serviced one at all?
I never wanted to work on them, and have no desire to do so. In my opinion - not profitable. But to do one up for your own enjoyment sounds cool.
I worked with a colleague a while back who worked on them and he used to spend quite a lot of time and sweat on them which further solidified my stance.
I wish you all the best with your repeater, like yo I enjoy a good challenge!
Just a thought, maybe there called repeaters 'cause you've yo work on them again and again and again?? :-)
I found this on the Bay,  it's very nice and it's 18k and it's jewelled to the hammers,  only problem is it's $5,500 not $500.  The one you bought looks like a bargain at the price you paid.
I hope so! But, I'm fully expecting to receive a "Basket Case" of a watch and just pass it on if it cannot be made right with a cleaning or something else simple... (really, I don't think anything is simple with regard to repeaters!)
Exactly as I suspected...The watch was not as described :thumbsd:  ...
First, it was a quarter repeater and not a minute repeater as listed. secondly, the hour rack was missing a tooth which would make the repeater function useless. But, to the sellers credit, he offered a full refund and a refund for my return shipping. Very happy with that!
Sounds like you dodged a bullet there, great that you got all your money back.  I can find lots of nice minute repeaters on the net, what I cannot find is the money to buy them.  I see them for sale saying "freshly serviced", and I wonder.  Well for a start, how many people are around who could service a minute repeater?  Secondly, cost, it would cost at least £500, say $700 for a service and thats assuming you can find someone capable of doing it.  Keep searching, it`s out there somewhere.
That's a shame Don, it could have been worse. Like the rest of the crew I'm looking forward to you getting one and sharing the info with us.
I'll keep a look out for one and let you know!
    • It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it.    I'll get a replacement from eBay.
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
