Repeater Advice Wanted...
DJW
I've been interested in buying a repeater for a while, but l'm starting to get serious about it now. I know that I should avoid any watch that does not function properly, Thinking that I can get it running. But, even if I find a properly running example, what are the most important things I should be aware of? BTW, most likely will start out looking for a quarter repeater to keep costs down. Also, I'm willing to spend about $1k for a good runner.
Probably buying from a reputable and well known source would be near the top of the list,  even if it costs a bit more.  I do not know enough to be able to offer any advice on repeaters except it would be nice to own one.   :thumbsu:
Yeah, I've been trying to read up on how they work and what to look for when buying them, but there's not a lot of info regarding them. All I've read was avoid any repeater like the "Plague" if it does not work correctly!
I Also read to look for ones that are "Jeweled to the Hammers" - Usually a sign of a higher quality watch.
Does anyone own one? Or, have you serviced one at all?
I never wanted to work on them, and have no desire to do so. In my opinion - not profitable. But to do one up for your own enjoyment sounds cool.
I worked with a colleague a while back who worked on them and he used to spend quite a lot of time and sweat on them which further solidified my stance.
I wish you all the best with your repeater, like yo I enjoy a good challenge!
Just a thought, maybe there called repeaters 'cause you've yo work on them again and again and again?? :-)
I found this on the Bay,  it's very nice and it's 18k and it's jewelled to the hammers,  only problem is it's $5,500 not $500.  The one you bought looks like a bargain at the price you paid.
I hope so! But, I'm fully expecting to receive a "Basket Case" of a watch and just pass it on if it cannot be made right with a cleaning or something else simple... (really, I don't think anything is simple with regard to repeaters!)
Exactly as I suspected...The watch was not as described :thumbsd:  ...
First, it was a quarter repeater and not a minute repeater as listed. secondly, the hour rack was missing a tooth which would make the repeater function useless. But, to the sellers credit, he offered a full refund and a refund for my return shipping. Very happy with that!
Sounds like you dodged a bullet there, great that you got all your money back.  I can find lots of nice minute repeaters on the net, what I cannot find is the money to buy them.  I see them for sale saying "freshly serviced", and I wonder.  Well for a start, how many people are around who could service a minute repeater?  Secondly, cost, it would cost at least £500, say $700 for a service and thats assuming you can find someone capable of doing it.  Keep searching, it`s out there somewhere.
That's a shame Don, it could have been worse. Like the rest of the crew I'm looking forward to you getting one and sharing the info with us.
I'll keep a look out for one and let you know!
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
