I ordered a watch for a mate of mine in the US from Fleabay.  As another friend had been very happy with his "Winner" automatic and mechanical watches I decided to order the same brand watch for my US friend.  AFAIK, the movement is an automatic Tongji type...21 jewels.
The problem is that when the crown is pushed down so that you can wind it, it is frozen solid.  When you pull the crown out to adjust the time, you can do so without any trouble.  I asked my friend to check if the crown was a screw-down type...no such luck.  Any ideas?  Sending it back to the Fleabay seller would almost cost as much as the watch.
Here's a link to an identical watch:
http://www.aliexpress.com/item/New-Square-Face-Skeleton-Mechanical-Hand-Winding-Mens-Wrist-Watch-Black-Leather/1850963493.html
Sounds to me there might be something broken that is causing the watch to foul up.
I thought maybe he had overwound it causing the crown to freeze up but then I remembered that most automatics have protection against overwinding.  The other thing is that my friend is a watch nut like me so I know he wouldn't do something that silly.
He said that the crown is stuck fast.  It will only move when you pull it out to move the hands and then it works fine.
Maybe its had water ingress at the crown seizing up the rachet wheel or similar , probably become clear with the caseback removed
No...it was brand new out of the bubble wrap.  My friend says that there is absolutely no movement at the crown when pushed in for winding.  When changing the time and pulled out it is fine.
Congratulations stroppy, I think you have just introduced your friend to the wonderful world of watchmaking!
At the price of the watch he has nothing to loose by opening it up and having a look, sounds like something is jammed or come adrift in the winding mechanism.
Max
Oh right ok , i'm still guessing thats where the problem is though , as i said i'm sure you will see the problem once the backs off
Thanks to all who replied with ideas.  I'll try and convince the guy to open the case to have a look.  If it was in my hands I would pop the crown and stem out and give the movement a good blast with an aerosol camera lens spray can but he is not confident in that regard.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
