I just removed the mainspring from the barrel on the 6139 I am working on. As a newbie was wondering if I can use moebus 1300 on the barrel wall. Does it matter? I also had the hardest time manually putting the spring back in, but I did it. Now I'm not sure if it has to hook to the barrel arbor right away or will it hook when it is wound?
Note that I also have D5 and could have perhaps used it for the barrel walls?? Not sure. I did not oil the main spring, I just put a few drops of 1300 on the wound spring. Did I totally screw up or is all ok?
If you are going to be working on automatics that slip to prevent damage when fully wound, then you should buy a braking grease. Do a search on this forum and the web in general, there is a lot of information out there regarding this.
Will order some today. Where do you typically buy from
Refurbished a 6139B last year and used Moebius 8217 on the barrel wall and HP1300 (wipe) on the spring.  It seems to be working fine.
I've bought quite a lot of my lubes from here http://www.ebay.co.uk/itm/Oil-Grease-lubricants-Moebius-swiss-made-choose-watchmakers-chronograph-/151144554717?var=&hash=item68d2e9c4b3
Have a look at the list further down in the advert and chose the one you want. There is a description of each lube and what it should be used for.
thanks for the feedback
thanks, I live in Canada so buying from the US from EBay actually turns out to cost me more than Cousins UK, as they have comparable prices and the shipping is cheap. Plus I don't get nailed with brokerage fees, a la UPS
Hi JD, I've bought from this vendor and it lists better (?) prices in US money. Try a search on ebay for elisabeth9679
That's the link I posted Bob.
Sorry Geo, but no, from here your link takes me to ebayUK (price in pounds) but if you do a search for the name as I suggested, from your account at home -- USA in this case or Canada in his case -- you'll get different results in the local country...it depends on the "options" this seller has and where he/she sells. (it is not a link but a vendor's name). At least that's what I get...
This is one of those sellers that I've noticed before lists on different sites in different currencies. I usually check which one is cheapest, it's not always the same one - presumably they use their own exchange rate ;).
Stephen
I've found that a light amount of D5 on the mainspring itself, is more than fine to lubricate it, and then you add braking grease to the barrel wall. I don't think you will find much difference in viscosity between D5 and whatever is recommended for automatic mainsprings. In addition, newer mainspring often don't need lubrication. (All automatics need breaking grease), and my master watchmaker friend, doesn't even lubricate automatic mainspring. Most are teflon coated, and are so thin, they have very little friction.
I use D5 on manual mainsprings as well, which may not be proper, but it seems to do the job just fine, and I've had no issues after the fact.
