Clothing
MWNAWR
Stroppy, remember the thread "Reducing humidity inside the watch" which I started in January. I cased up the watch in this humidifier grove box I made. So far the watch did not fog up anymore.
Dadistic, it's home made using a plastic aquarium, kitchen gloves, two top part of plastic cookies containers used as holes for the gloves to attach on, cut two holes on a transparent plastic bag, dehumidifier substance, a mini fan to speed up the dehumidify-ing process and a digital humidity meter.
Edited by steven
Dadistic, it's home made -
Hah! No wonder I couldn't find it :-) You sure did a professional looking job. Saw a similar lab glove box for sale for about US$400. I remember you mentioning solving your humidity problem, but I figured you'd just dehumidified your entire workspace.
Last time I had condensation in a watch, I took the back off and heated it up with a hair dryer before I closed it again. Seemed to work.
Thanks!
Thanks!
I have "rescued" a couple of smartphones for the kids of friends of mine using the hair dryer method.  You could do it if the owner had not attempted to power on the phone after the inundation.  I would take the battery out...unscrew the motherboard as best as possible and then put the works into a bucket and gently heat the air within using the hair dryer.  This method worked with about half of the flooded phones...the rest were DOA no matter what I did.
Have you tried a bag of rice? Bury them in rice and leave in a dry place, it should work too, the rice will absorb the humidity.
Yep...that works for phones that have been in the pocket during a downpour but not for ones that have fallen into the dunny...etc  (don't laugh...it happens more often than you think).  :D
Edited by stroppy
  • 5 weeks later...
Friend gave me an old cloth to clean my car. The cloth turned out to be a very good cotton apron. Its old but well made. I now use this to protect my clothing and watch parts when I am repairing.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
