Hi
I'm in the process of stripping down my own Omega 285 for a service. Not something I've done before, and I'm trying to be careful :). The attached photos show a part that is puzzling me. Is the wheel permanently attached to the bridge, or is it removable? I don't want to just pull at it. Thanks
Stephen
The top wheel should really have been pulled off before removing the bridge. There is a special Presto No3 puller for doing this that has two claws on one side, and one on the other.
Do not try to remove the wheel from the bridge without the bridge being on the movement!
post-124-0-86757400-1455446756_thumb.jpe
post-124-0-28327100-1455446805_thumb.jpe
post-124-0-27952800-1455446862_thumb.jpe
The wheel on top of the bridge is the indirect centre seconds wheel and it is a push fit onto the extended third wheel arbor which projects through the bridge.
It can (and indeed should) be removed to facilitate cleaning and oiling of the pivot but you must be careful. Being a push fit it just pulls off, however, the extended arbor is very delicate and any action that causes the wheel to cant or tip unevenly to one side or the other can very easily snap it.
You can get a puller specifically for the job which looks like a modified "Presto" type hands puller, another fairly safe approach is to use two single edged razor blades pushing in evenly on opposite sides to lift the wheel. Once there is sufficient clearance you can graduate to Stanley knife blades to complete the job.
Reassembly is best achieved using a staking tool, but if you don't have access to one then just careful even pressure.
Thanks very much guys, I'm glad I asked now! It's a shame I can't find a detailed service sheet anywhere, there are a few things about this movement slightly different to what I am used to. So to remove this wheel I need to apply even pressure undeneath the top wheel, with the bridge firmly secured?
Stephen
It all went fine thanks, and it's back together now. The only problem is today I managed to lose not one but two parts! One of the cap jewels (not sure which one, or even if they are different) shot off into space. I do have spares, but I have no idea how thick the original was. Is there any way to find out, or do I just have to experiment?
As well as that the intermediate wheel has vanished - it was there as I put it in place. I briefly turned the movement to check on something and obviously it fell out. Can't find it anywhere - I think it's the largest piece I've lost so far! Fortunately the watch is mine, but it is very annoying. I can't find a reference to this part. Are intermediate wheels known as anything else? Thanks
Stephen
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
