I guess it is raining Primas - I just received one that I had taken a chance on from an Ebay seller in Pakistan. Seems to run quite well, but when in setting position things are a bit stiff so that will be reason enough to open it up and take it apart!
Edit- Looking at the photo I think I'll look examine it more closely to see if it's a redial, but that would be OK because I really didn't spend any more than you might on a Mumbai special Seiko.
Edited by Geotex
Nice, yours looks a bit happier than mine. Any idea if these are radioactive lume?
Edit: after a bit of reading, pretty sure it is.
Movement pic and probably away in a drawer or sold then...
Pretty pleased with the strap though...17273340599325987077725162245177.thumb.jpg.ba2ddee730654647ad78a4b4f176ce05.jpg
And (while I imagine there are loads of them) I've never seen an acrylic like this before...
Edited by tIB
On mine, the dial does appear authentic and the lume under the scope is old and degraded but not curently radioactive (based on an inexpensive but functional Geiger-type detector) which would rule out radium. So, it's likely relatively short-lived tritium lume which matches with the rest of the watch that dates to the 70's.  So yes, radioactive at one time but mostly decayed by now and not at all the kind of exposure you could get from working on a radium-lumed watch if that is a concern.  You need a different type of detector to actually measure tritium, but enough half-lives have gone by that you can assume a low risk just with math, and it doesn't produce deeply-penetrating rays or particles in any case.
If I read the dial correctly, yours is a "Keepsake" version which is also a later-years model so I think it would be very unlikely to be radium, but I'm not a West End expert.
Thanks for the info - I've already caused mine a mischief, in that the stem now pulls right the way out of the case. Think there's something threaded...
I've got this lovely Lord Nelson watch being delivered! Unfortunately to my fathers address as I forgot the change the delivery address on Ebay and for the low bargain price of £13 including delivery I'm very happy with it.  I have had a quick google and haven't been able to find much about the maker/brand but I think its a stunning little watch for the price!
18 minutes ago, RichardHarris123 said:
I'm guessing it's a pin pallet.
That was my thought too. "Jewels" is conspicuously absent from the dial, but I love these gilt numerals.
Another oddball 70s vintage on its way to me. This time a Benrus Electronic Citation. No pictures of the movement, but I bid an amount I was comfortable being scammed out of, and what do you know I won the auction anyway.
image.png.37c8fce1d3fd225a9f52ac0564ab569c.pngimage.png.60ba246968a5f23e3bf1066a1727e561.png
I found a thread suggesting it should have an ESA 9154 movement inside, which looks pretty neat. Taken from calibercorner.com:
7 hours ago, Nucejoe said:
A Baum Gartner or Ronda  cased with  rather eliquent looking gilt numerals.
Or EB 8800
34 minutes ago, Razz said:
Or EB 8800
There is allegedly an EB8800 variant with sub seconds but I have not encountered one. If this turns out to be that, I hope we get to see the teardown.
8 minutes ago, rehajm said:
…two Rollies and an Omega- nice, but the Lionel is my favourite 👍🏻
If only. Something tells me they'll only be any good for their movements.
…so long as they aren’t released back into the wild I’m quite fond of an interesting knock off…
I wear this one all the time, mostly because I like to flex about the lot it came in- a mixed lot of ‘costume jewelry’ and a also a ladies longines for a couple hundred quid where all the pearl strands and earrings and pins were the real thing..😜
For me if they aren't legit then they'll be stripped and the dials chopped and binned.
3 hours ago, AndyGSi said:
So my parcel arrived and as expected they're fakes so now it's just a case of trying
to sort out what movements they are so I can get stems and give them a try.
Ooumph, i assume it hasn't been a big hit you've taken Andy if you were expecting counterfeit.
£15.00 for this lot of parts so still not done bad.
Ah thats not bad Andy steel braclets, fastening clips and links always come in handy for those repairs. I've picked up many decent bracelets that were too short or damaged, folk of the 50s and 60s were mostly slim and small wristed lol. Caseback,  plenty of good watches out there with missing backs, and you just never know what may fit . I dont think you can go wrong with hauls like this and they usually go cheap
17 hours ago, AndyGSi said:
Miyota movements. Not sure which exact ones, but the large one looks like a 8205 (but the balance cock on yours doesn't have the +/- engraving, so not 100% sure).
Thanks.
Yes the large ones do look like Miyota but they've got sub dials at 3, 6 & 9.
Think I'll probably just put them on eBay as a job lot for spares or repair.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
