Bent Arbor And Broken Teeth
transporter
Struggling on this one guys, im in the process of servicing a smiths empire 3 train westminster chime grandmother clock movement, all is stripped and cleaned and awaiting a few bushes to be done ( easy part)
The hard part is trying to find a new/replacement part, its the first wheel of the going train, the movement suffered a broken mainspring at some point in the past, this in turn bent the arbor and wheel and bent 5 teeth on the wheel, 2 of which snapped off.
I have my local watchsmith searching for a replacement but he's having a hard time trying to find one. It's got 62 teeth and is 41mm in diameter. I will get the pinion to pinion measurement in the morning, i haven't got the part at the moment somi will measure between the plates tomget anear as damn it measurement.
Have any of the members here possbly got one lying around that would be willing to sell so i can get this movemnt back together and working again.
many thanks for any help in advance
Try these guys. I know perrinwatchparts used to supply new barrels
http://www.perrinwatchparts.com/cat_name/clock_parts.aspx
http://www.ycbclocks.co.uk/index1.html?lang=en-uk&target=d114.html&gclid=CK66o7i-mbsCFZHItAodlSwA2g
http://www.clockworks.com/clock-parts/clock-parts.html
Done abit of surfing on the net, ( not the ocean, to messy at the moment) and have come across a gem of a book called clock making in in england in the 20th century ( i think ) anyway i have finally found the same mark on the rear plate in this book as i have on this movement, it dates from 1938-1940, its a pre war Enfield K1 chiming grandmother clock movement rebadged as smiths empire for marketing purposes.
so the golden question now is where to find Enfield clock spares for a K1 movement ????
Spares are always a challenge & I dare say you have looked at timesavers or there is another guy who,s worth emailing John Wardle see his web site below:
http://www.johnwardle.co.uk
another link.
https://www.cousinsuk.com/category/longcase-clock-parts
​There are guys who specialise in making parts & they advertise in the BHI mag every month. It depends on how much your budget stretches as they are not cheap.
Oldhippy, im actually looking at poossibly replacing the broken teeth on the wheel and having a look at trueing the wheel, as for the arbor would you reccomend using heat to help bemding it straight again?
No I never used heat for this. You could fix it in the lathe gently turning it by hand and tapping it with a wooden mallet until it was right. It takes time but its cheaper then making a new one. With the wheel the broken teeth can be fixed by finding an old wheel with the same teeth, cut out what you want and cut and file the replacement part and solder, if done correctly after cleaning you should hardly see the join.
Here's an example of this type of repair, not my work but the work of a previous repairer,  there are also some good youtube videos showing the technique. :)
That is a very poor example. As I said when it has been completed you should hardy see the repair. I would expect an apprentice with very little know how to do better then that disgusting mess.
Glad it wasn't my work, I would have been ashamed of that !  but as you say , a nice French movement  circa 1900.
I'll be honest guys ive never done a repair like that before but I'd like to think that I would be tidier than that, im kinda making my mind up here to attempt the repair myself, i dont want to have my local smith waste to much time going through his stash of old movements trying to find me a part for what is a non profit let alone paid job on what is really a cheap mass produced clock movement.
If you haven't replaced teeth before, why not try with some old stock and replace a single tooth.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
