Removing Hands Of Fusee Watch ?
cdjswiss
I am working on my first fusee lever watch. Here is a photo of the hands. The square nut is used for setting in the clockwise direction with the appropriate key, and I assume that to remove the minute hand the nut must be unscrewed anticlockwise using the same key. It is extraordinarily tight for such a small nut and before applying more force I should be pleased if someone can confirm that it should be unscrewed.
I've just checked, and pulled one from a movement I had lying around.
The hand has a square hole in the middle. Pull it off the square, them pull off the hour hand. That leaves what looks like a canon pinion with a square. Remove the dial, and the hour wheel will slide over the pinion and square. You will now be able to pull off the pinion with the square. It is fitted on a taper, and requires a good pull or a bit of leverage.
Here's a photo to help.
post-124-0-03753600-1450708109_thumb.jpe
Many thanks gentlemen for the correct information. Here is the result.
It was sold as a non-runner. After cleaning the balance it was running well for 36 hours on one wind but only the second hand moved. So the next step is to tighten the cannon pinion. Thanks George for the illustration of that step. A couple of taper pins only and I shall have the dial off, but that will await the morning as it is now time to sample a bottle of Cahors.
Yes, very fine 2010 vintage.
If the cannon pinion is slipping it should come off easily?  But I do fear that the problem may be more serious. However, as the second hand turns it cannot be too severe. Perhaps a broken cannon pinion?
Colin, it is not a canon pinion as you used to. The pinion has has a precision taper and don't compress it as you would a modern canon pinion. When fitted this pinion is not meant to slip at all.
To tighten the setting operation of the hands, you have to remove the whole shaft that goes through the centre wheel. You will have to put a slight bend in the middle of of this so that it increases the friction fit inside the tube of the centre wheel.
To re-fit the geared pinion with the internal taper, you have to support the other end of the shaft that you have just bent slightly, and tap the pinion onto it with a ounce and very lightweight hammer. It is the same as fitting a morse taper. Once you have that reassembled, fit the minute and hour wheel then the dial and hands. The hands will press on fairly easily.
There is a possibility someone has been working on the watch before that didn't know how the system works. The first time I came across it and saw a bent shaft I thought there was a problem and straightened it. Guess what, the hands were so slack the movement wouldn't drive them and they turned like propellers when I tried to set the time!
I couldn't wait. Here the cannon pinion came away easily and a 0.9mm watch hand fitted to the centre arbor appears to be keeping good time. There was some goo under the minute wheel that would explain why setting the hands sometimes met a sticky spot but was mostly too free. It remains to tighten the cannon pinion using the Bergeon chisel tool in my jeweling press.
DON'T DO THIS Colin!
The pinion has to be rock solid on the shaft, if you use your canon pinion tool on it you will ruin the internal taper. The pin must be removed and bent slightly where I have indicated to get the correct friction.
post-124-0-40849900-1450725061_thumb.jpe
There is usually a small shim washer on the other end of the shaft to give the correct end shake.
Thanks George. Your illustration is of what Fried calls the clock type of centre pin system where the cannon pinion is firmly fitted to the pin. Here is a photo of my cannon pinion and I see a dimple. My watch presumably has the click-on cannon pinion?
I now realise that I cannot use the Bergeon chisel tool. I must indent the dimple further with a staking set punch and a short pin fitted inside the blind canon pinion to control the dimpling.
Comments and advice before I start to hammer?
The centre arbor has a slight taper from 0.96mm at the base to 0.93mm at the tip. But there is also evidence of the use of a click-on cannon pinion. When I hold the arbor firmly in a pin vice it doesn't turn. All of this suggests a dimpled click-on cannon pinion system. The watch is dated 1900.
The watch that I pulled the pinion off of yesterday pre-dates 1900 and has the the same dimple ground out of the side. The trench watch that I worked on a while ago was from 1913 and has the type of bent pin system that I'm talking about, hence my concern about you damaging your watch.
http://www.watchrepairtalk.com/topic/1520-trench-watch-help/?hl=%2Btrench+%2Bwatch
Having said all of the above, if as you say you cannot turn the pin using a pin vice it suggests otherwise. Is it possible to have a look at the lower end of the centre wheel to see if it has a small pivot, or a through going pivot with the pin that I describe, just to make sure?
Good sleuthing George - It has a small pivot. Case closed. I shall dimple.
I'm a bit late on this one. It just pulls off just like any cannon pinion.
Beware of the cannon pinions that should not be pulled off.
I quote Fried:
"Therefore removal of this type of canon pinion (hollow pinion type) should not be attempted in the same manner as the snap-on type as this might result in 'springing' the main plate".
This was the concern that Geo was voicing.
I quote Fried:
Thanks for the advice. I've been retired now for many years and I have about 30 years under my belt as a watch/clockmaker.
Happy Christmas
For the record:
The cannon pinion of my fusee watch has the ground-out notch with a very small dimple in the centre. When I punched the dimple to my surprise a separate plug about 0.5mm diameter, that you may just be able to discern withing the pink circle, was driven into the pinion up to the brass pin that I had slipped inside. This plug could be seen under the microscope within the pinion projecting about 0.03mm. It was all that it needed to give the cannon pinion the tight, but not too tight, fit onto the centre wheel arbor. The minute dimple is put there simply to centre the punch. They certainly knew how to build watches in those days. It is now running perfectly.
    • Hello and welcome fromLeeds, England, it looks like you are well on your way.  Multiple accounts are against forum rules, if you give the name on the other account it can be removed.
    • That has become habit to quote since learning about electricity as a kid. I'm sure even my old school sparky (74) still uses divisions of 240v to work out current draw and fuse ratings. Uk  Rating on my travel kettle averages out at 230volts 😆
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
