What's your thoughts on this Rolex Sea-Dweller, ref. 16600, calibre 3135 project?
This may help, suggest covering with plastic film when removing and re-installing if your tweezer skills are not 100% yet 1971-Citizen-Technical-Information-03-Watch-Movement.pdf
It all depends on the movement but if you've got to get a new arbor then you'll need to know that anyway.
I can't see how that would be cheaper as I help my local charity shops on a pro bono basis. But of more interest to me would be to understand how to work out the specification of a replacement balance given that the chance of being able to order the part from the company or OEM must be effectively zero.....
It looks like after rolex someone serviced the barrel with way too much P-125 chronogrease- either that or coffee grounds. Clean it up and you’ll be good to go… https://www.jewelerssupplies.com/chronogrease-p-125-420.008.html
Haven't handled a Rolex in a long time but that's not natural. If the barrel is still useable then just grease as normal.
