Winding Stem For Unknown Mechanism
nambutler
Hi
Can anyone recognise this mechanism. It's fitted to a copy omega which has some sentiment value to me. Im looking for a replacement winder stem
Here's the stem against a similar stem which is too small
The mechanism in question
I've also been told I can get the small piece out of the crown by leaving it in aluminium potassium sulphate solution to resolve the steel stem. Is this a recognised way of recovering a crown?
Any help would be really appreciated
Best regards
Mark
it's a recognized way of removal - in fact, it's something i have to do with a seiko crown.
i was told that the alum will attack only the stem leaving the crown intact. however, someone else replied that some of the stems are stainless steel. which would technically eliminate the effectiveness of the alum.
so the answer is: maybe.
i'm gonna try the alum on my stem anyway.
Thanks.....fingers crossed! Appreciate your help
Nope that looks different . But read that it could be a ETA copy. So a ETA 2824 or 2836 stem would fit . Did n't have one but found pictures on the net. And they look the same . you could measure and see if it would fit?http://www.windingstems.com/eta.php
Look under the 2824-2 stem. There is more info.
Or measure the A and E on your stem and enter them in the search . There will come up suggestions on fitting stems .
Edited by rogart63
Thanks. I'll give the a try and see what comes up. Much appreciated
From your pic there looks enough left to use a stem extender if you can't find a new stem and alum powder does work on a steel stem in a stainless crown it's helped me out before
Why didn't i think of that ? Good tips. A stem extender would probably work fine.
    • There is one Oris there at least, and if you could get a Unicorn for this price!??! 😄 It says that they don't work though, you might need to figure out what a Unicorn eats then. 😉
    • I wonder whats inside, bought it blindly, not cheap at all.
    • Here's a quick Gif I made to show truing the balance using callipers. This has such a slight wobble, but is within acceptable parameters. The important thing is the balance doesn't touch or rub anything when in operation. This is an Eterna Tank. Here's a pic of the balance freshly rivetted with a new staff in the movement
    • I just poked an inflation calculator, and $5 in 2020 would be about $6 in 2024. Doesn't fit very neatly into any status codes, which stop at 5XX, but that's honestly somewhat arbitrary outside of a clever pun for those that dabble in such things. Back during the pandemic, I would spend a good chunk of idle time in the evenings scanning through hundreds of listings a night, and I would only land 1-2 a week max. I would often go months without finding something suitable. A very small percentage of the watches in the price range are worth pulling the trigger on for my purposes. The number floating through the thread here may be somewhat deceptive.
    • Hi, guys I got there in the end after several attempts using a screwdriver and Rodico, I couldn't wait for the tool to arrive and was getting pretty confident handling the stud screw without it flying away. At first, I was using far too much Rodico, and then realized you only need the smallest amount inside the screw slot. Putting the cock back onto the movement also helped as it gave me more to hold onto while my shaky hand tried to align the screw wobbling away at the end of the screwdriver😁 Anyway, job done and I can move on. Thanks again for all the advice it's really appreciated for a beginner.
