Hi,I have got a original Stuhrling Skeleton watch and got a problem with the hands they keep spinning,to it unwinds,think the leavers and horn is missing on one side,but see it is not broken,is it an easy fix can any one advice me please thank you.
I agree. Maybe is my old age but I barely understand what the problem is. Hands are supposed to spin while the watch is working...I don't know about the horn...are you talking about an alarm feature, a sound...??? A picture will be great.
Cheers,
Bob
sounds like a bad pallett. i had a seiko that had a missing palett jewel. when i would manually wind it (as i sometimes do if i have them apart)  the hands would spin around until the power was exhausted in the mainspring. the second hand was a blur. it was cool to look at.
So you need to help us on this one as already suggested pictures would be nice so we can see what you're seeing. Otherwise we can guess. So history of the company can be found at the link below very interesting description and they also have a repair service. So the term manufacture of watches is always interesting for me I tend to think of someone who makes the movements but here it means they case up other movements. Casually the watches tend to have a Chinese look to them so finding spare parts might be interesting perhaps.
http://www.stuhrling.com/history.html
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
