Hi all, please could some tell me the difference between uses for a lever press and non lever press horia jeweling tools?
Can anyone also tell me if the tool in the photo is missing something on the table?? It doesn’t look the same as modern ones available from Cousins etc.
Edited by Bigjay
Spelling mistake
There were literally tons of these made, with spindles that took 3mm pushers as well as 4mm. Many were modified in factory settings for specific tasks.
The difference between screw type and lever type is really a matter of preference. I have many examples of both, but for more than a couple of decades only use the lever type. Just today one of my workshop mate's employees asked me for a screw type and I gave it to him but realized it needed a good servicing as the oil in the threads had gummed up.
As made, they both come with either 3 or 4mm spindles, 3mm being most common, with a 4mm hole in the base for stumps which matches most other makers as well as staking tools.
Your image has extra holes that probably correspond to a purpose-made jig or holder. The central hole looks to have a stump, and is likely 4mm, but could be anything.
A plus of the lever type is the spindle comes out and you can use standard (Seitz, Favorite, Chatons S.A.) holders for reamers and drills in it.
Expand
That’s great! Thank you for the comprehensive reply.  I’ve just bagged it for £45 on the bay of E so hoping it is a genuine Horia as the advert described it.
Expand
It looks Horia!
If it's been modified beyond those holes is to be seen. My gut says it's A-ok.
So, i’ve bought it and cannot work out what anvils and pushers I need to get for this.  The stump on the table is fixed and as I’ve bought it blindly (not really knowing how to use it but seemed like absolute bargain compared to buying new from Cousins and it is marked Horia on the lever!) I may be have cocked up a bit!! Any help would be appreciated!
Edited by Bigjay
Looks to me like it's a crystal press.
Edit
Just done a quick search and it does look like a jewel press.
Are you sure the stump is fixed? Can you post a closeup photo.
Edited by AndyGSi
Well, after a bit more deduction (Sherlock Holmes style) it would appear that the stump was a stuck anvil….I think?  Still dont know what the three extra holes are for?
  On 2/6/2025 at 7:19 PM, AndyGSi said:
Someone may have modified the base to take a movement holder or something like.
Does it take the 3mm or 4mm spindles?
Expand
I think it takes 4mm spindles as I measured the shaft of the removed stump as 3.96mm
  • Similar Content
    • I have no experience of Rolex, but that doesn't seem normal. Do you know about the history of this watch? The barrel appears to have been dry for a long time, judging by the wear on the inside of the lid. In any case, it needs a good clean and fresh grease.
    • The problem/challenge with these things is that you don't know what brilliant solutions previous watch-tinkerers have come up with. Are all parts even "original"? Did the watch run ok (-ish) when you got it? One possibility is that a replacement staff has been fitted and turned out to be a loose fit.  Some of this has been discussed in the following thread:
    • @GuyMontag good find! Even the micro stellas are cloned in the Daytona fake! Around $2600 is mentioned in the thread. https://www.reddit.com/media?url=https%3A%2F%2Fpreview.redd.it%2Fnewest-development-from-ace-v0-61r4zxq1q2xd1.jpeg%3Fwidth%3D1080%26format%3Dpjpg%26auto%3Dwebp%26s%3Dd5dd3a29a3d1668077d4a4c894a09c76f6f66de9
    • See I wondered about this because Frei only lists one part for 18 size, no left or right options whereas they specify left and right for the other sizes. (I happen to be working on a grade 88) I recall seeing an old video of Elgin making laps and jewels in the factory (maybe you were the one who shared it) I have one very weird warming tool which has springy jaws that can open wide enough to hold this type of fork flat, and it swivels so you can position either side over the heat source. It works great for melting shellac on a firmly held fork EXCEPT can you guess what its fatal design flaw is?....   ....you cannot open the springy clamp once it has been heated because you would need to pinch them both between your fingers and you get a second degree burn. Genius.
    • The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.   From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
